Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Harness eyebolts...
Old May 10, 2008 | 09:59 PM
AW's Avatar
AW
Default Harness eyebolts...
I finally got my eyebolts in as they were backordered for a while. I ordered the longer ones as I know the seatbelt mount needs a longer bolt. Should I order shorter ones for the other mounting points or just use these with another nut, or worse case cut if they are too long.
Old May 11, 2008 | 10:08 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Harness eyebolts... (AW)
Double-nut FTW. Too long is better than too short, in this case. You might have to trim/grind them a bit. Are there two backing plates for each bolt? Hard to tell from the pics.
Old May 11, 2008 | 10:19 AM
AW's Avatar
AW
Default Re: Harness eyebolts... (Stinkycheezmonky)
No backing plates, I ordered some Sparco ones that I am waiting to come in to use these eyebolts with. Only bolts I am worried about are the ones that will be used on the center tunnel. Based on the length they may hit into the exhaust so some grinding may be necessary.
Old May 11, 2008 | 11:10 AM
hayabusa160's Avatar
i just installed my harness this week using those eye bolts the tunnel did not have any issues with making contact with the exhaust.
in the back i used the old seat belt locations to mount the harness i ended up having to use about 3 washers and the lock washer that those bolts came with to space it out just right so they wont bottom out.
Old May 11, 2008 | 01:50 PM
Lo-Buck EF's Avatar
i have some short ones if you need them. your gonna need them when your using them in the tunnel or rocker
tpod
May 10, 2006 10:37 AM
AWD: Jeff
Honda S2000
14
Apr 19, 2006 10:52 AM
AWD: Jeff
Apr 12, 2006 05:35 PM
sporkcrx
Jun 22, 2003 11:03 AM
GS-R_nut
16
Aug 22, 2002 02:32 PM
