Need help with tire size?
I need help picking a tire. I have a 98 integra rs stock brakes. I am pretty confused on tire size. I want to be set of for turbo street class so I looking at mickey thompson et street radial. But I am in Texas and dont really have alot of money to travel to races. Alot of the racing I will be doing will be on my local track at whatever class they will put me in. Anyway could someone help me out. Here is my setup. I have b16 gearing w/ls 4th gear and ls final drive as far as trans here is the rest.
Bottom end:ls block bored to 84mm and sleeved by golden ealge,balanced and mircopolished stock crank,eagle rods,arp rod and main studs,arais 9:1 pistons
Top: gsr head pnp,ferra valves and valve guides,bc dual valve springs,bc titanium retainers,5 angle valve job,edelbrock mani,golden ealge cam gears, bdl 72mm throttle body
turbo setup:sc6152e, inline pro stainless steel t3 mani,3in downpipe,spoolin performance 2.5in piping, precision 750hp intercooler, tial bov and tial 44mm wastegate,hondata s300
fuel: walbro 255,1200cc injectors, bdl fpr
24.5 x 9 x 13 Mickey Thompson ET Drag.
You will have a much more reliable car running on slicks than on drag radials. Slicks are a LOT more forgiving that a radial tire can be.
Thanks I kinda knew that with a slick size but if I am able to make it to a race and run turbo street I have to run a dot approved tire. What would be a good size dot approved drag radial that would not affect my car and go good with my gearing if that makes sense. Thanks again
