question 95 gsr hatch tach dont work LOOK!!!!!!!!
Old May 10, 2008 | 07:58 PM
donvito#1's Avatar
Default question 95 gsr hatch tach dont work LOOK!!!!!!!!
so this is the second time this happened 2 me my old 94 gsr hatch had an 2000 obd 2 gsr swap with a obd1 ecu and the tach didnt work i tried everything it still didnt work i just threw a 2001 gsr swap in a 95 hatch with a obd1 p72 ecu and the tach dont work again i know it worked because it had a ls swap right before i did the swap so my question is since it an newer obd2 swap should i be runnin and obd2 ecu anybody have the same problem info please
Old May 11, 2008 | 12:13 PM
hybridmath's Avatar
Default Re: question 95 gsr hatch tach dont work LOOK!!!!!!!! (donvito#1)
are you using the obd2 engine harness
Old May 11, 2008 | 03:31 PM
donvito#1's Avatar
Default Re: question 95 gsr hatch tach dont work LOOK!!!!!!!! (hybridmath)
yes i am
Old May 12, 2008 | 09:51 PM
hybridmath's Avatar
you got to run a wire from the distributor directly to the tack wire in the driverside shocktower harness dont remember which one it is for some reason the engine harness uses a diffrent wire location or its not there at all not exactly sure but thats how i fixed it on my old gsr swap in my 92 hatch i think distributor wire is white with blue stripe
Old May 12, 2008 | 09:52 PM
hybridmath's Avatar
sorry for late response been a busy couple days
Old May 13, 2008 | 09:12 AM
donvito#1's Avatar
see that the thing i tried that i got some kinda signal but it bounced around not accurate and that happened 2 both my cars
LILA INTEGRA
Jun 23, 2013 04:52 PM
carlosd68
Dec 21, 2006 02:06 PM
nekoabandoned
Apr 19, 2006 08:47 PM
blackboosted2
Mar 20, 2004 07:18 AM
Evil_Wizard
Mar 17, 2002 10:00 AM
