accord 1999 ex coupe question
Old May 10, 2008 | 04:29 PM
sDc5's Avatar
Default accord 1999 ex coupe question
i have a honda 1999 accord coupe ex, the door handle on the driver side has a jammed key hole from recent theft. i'm figuring out how to take off the door handle and to remove the key from the handle if possible. i've looked all over the internet and haven't found anything that gives me good enough detail of how to exactly remove the handle from the door, pretty much i'm at the part where the metal backing holds the handle by the lock back side. dont know if you this makes sense but if you might know some info that could help it will be appreciated
Old May 11, 2008 | 10:42 AM
hondadude's Avatar
Default Re: accord 1999 ex coupe question (sDc5)
there should be 2-10mm bolts that hold the handle assy, that are inside the door.
You also need to remove the latch and lock linkages.
FWIW you can take your new lock barrel to a locksmith and have the tumblers set to fit your ignition key.
masospaghetti
Oct 7, 2014 04:03 PM
nhanimator
Honda Civic (2006 - 2015)
Apr 14, 2011 06:17 PM
scasper76
Nov 19, 2008 09:52 AM
dwayne1413
Apr 1, 2008 01:32 PM
rollercosta123
Jan 6, 2007 08:30 PM
