D-series Tranny?
Old May 10, 2008 | 03:25 PM
924doorEG's Avatar
Default D-series Tranny?
I was wondering what D-series hydraulic tranny has the closest gearing?
Old May 10, 2008 | 04:02 PM
makoto's Avatar
Default Re: D-series Tranny? (924doorEG)
ever go to any other forum? TECH has this in it's FAQ:
http://www.knology.net/~jedikl...s.htm
Old May 10, 2008 | 08:10 PM
RedRocketDX's Avatar
d16y8, 96-00 EX
Old May 11, 2008 | 09:58 PM
danomatic93's Avatar
^^ditto the EX/Si transmission from the 96-98 Civic or EX transmission from the 99-00 Civic. Make sure the trans has the B000 code on it. (Stamped into the trans)
Old May 11, 2008 | 11:58 PM
924doorEG's Avatar
So will the y8 96-00 ex tranny bolt right in to my 92-95 civic d15b7?
Old May 12, 2008 | 08:42 AM
makoto's Avatar
Default Re: (924doorEG)
it should... still hydro, and the splines on the input shaft should be the same.
Old May 13, 2008 | 12:41 PM
blk92_d16's Avatar
An untouched one from the factory would be the Ex/Si as others have mentioned. Then you do have the option to change up some gears and the final if you dare.
GreenD16Y8
Jun 12, 2005 12:59 PM
jdm_eg
Dec 21, 2004 06:46 AM
EK45VTi
Sep 13, 2004 10:58 AM
StRacer
May 4, 2004 01:04 AM
Mr. Thunderlips
22
Apr 16, 2003 08:29 PM
