Ingnition Timing Part 2 (possible solution & Pics)
Old May 10, 2008 | 03:11 PM
Tiger_Si's Avatar
Default Ingnition Timing Part 2 (possible solution & Pics)
This is Part 2 of https://honda-tech.com/zerothread/2286953
Quick Recap, My R was running like **** and timing supposedly was bad and CEL 9 was showing up....
Finally i got some time to work on the R, and this is what i found....
Dizzy cover missing the lower bolt (not showing, but it was missing)
we find a really dirty distributor, that it seems to be missing the leak cover and the rotor is pretty beat up.
closer pic
ohh and the retaining rotor bolt was missing as well, it was just laying on the cover..
do you guys think i could still use this cover....
anyways, without going to honda, where can i get a replacement rotor or any other dizzy part that i might need?
PS, thank for all the input on my part 1 and the people who recommended to look in the dizzy.
Old May 10, 2008 | 08:07 PM
Erik95LS's Avatar
Default Re: Ingnition Timing Part 2 (Tiger_Si)
Same thing just happened to me actually. I wouldn't use that cap again. I would get them from honda (particularly sonsacuraparts.com), but you can get them from any autoparts store, but they'll probably have to order them. You may also want to clean some of that dust out of there and make sure there isn't any other debris floating around inside.
Old May 10, 2008 | 08:38 PM
an2ny888's Avatar
Default Re: Ingnition Timing Part 2 (Erik95LS)
hmm that looks like the red dust of death, i'd check the distributor bearing if i were you
Old May 10, 2008 | 10:53 PM
Ultraspeed DC2's Avatar
Oh yeah, I was busy today but I found an explanation for the timing being off at the crank. My friend and I took a caliper to the original timing belt cover and a brand new one from Honda. The newer ones are made from a different mold and there is a significant difference in timing reference point.
Old May 10, 2008 | 11:18 PM
Thrizzle's Avatar
* B A N N E D *
Default Re: (Ultraspeed DC2)
You need a new cap/rotor and you're set.
Cheap fix
Old May 11, 2008 | 10:50 AM
Tiger_Si's Avatar
sunday morning update..
i got an ultra JDM Duralast Rotor from Auto zone, and i just intalled it, and it runs like a champ!!!!
i am still using the beat up cap too, and it is idlying well, it is at 800rpms, i rather have it at 750rpm tho.
in a couple of weeks i will order the OEM leak cover, cap, and rotor.
Old May 11, 2008 | 11:04 AM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tiger_Si &raquo;</TD></TR><TR><TD CLASS="quote">
in a couple of weeks i will order the OEM leak cover, cap, and rotor.</TD></TR></TABLE>
Old May 11, 2008 | 12:55 PM
heel_touge's Avatar
OEM is the only way to go.
IN reference to the red dust of death.... could a seized bearing cause the ignitor and or coil to burn up quickly? or are you more concerned about the oil leak into the housing&gt;?
Old May 12, 2008 | 11:17 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Ingnition Timing Part 2 (heel_touge)
if you go to an Auto parts store, it's fine to get a non Honda one as long as it's made by YEC
mossberg
Aug 21, 2018 04:44 PM
thevtecnician
Jul 30, 2013 02:38 PM
daylon1650
Feb 10, 2009 06:55 PM
thizboii
Apr 21, 2007 06:18 PM
dem0nk1d
12
Apr 8, 2007 09:50 AM
