searched. clutch/flywheel noise?
hey guys, i have a 88 crx si with a b16a engine, just replaced the flywheel for a fidanza 7.5lb flywheel, and went with the clutch that was already there, the guy replaced it before i bought the car(its a stock exedy disk). my problem is after we put the flywheel in im getting a strange noise when I accelerate through most of my gears but the noise gets quieter as im in a higher gear. the noise sounds like the same whining noise when i compression brake, the noise was never there before(when accelerating, i notice most cars make the noise when they compression braking), it happened after we put the flywheel in. my question is has anybody else experienced this and what should i look to fix. and could it possibly be my speedo sensor possible not be lubed good enough and is whining? thanks for any info
-pat
-pat
DanCan'tSwim
13
May 31, 2012 05:02 AM
