how to bleed power steering system?
with the car running and the fluid topped off... turn your steering wheel slowly all the way left and all the way right... do that a few times... and refill the fluid as needed... but what exactly did u do that u have to bleed it? and i hope ur using honda PS fluid =/
Jack the car up to take the weight off the front wheels and just turn it back and forth. USE HONDA PS FLUID. It WILL F your pump and seals up if you use anything else.
mimog3
Apr 28, 2013 11:38 PM
