Accord climate control
Ok I have searched and then I searched some more.
So I got the climate control form a 90 accord. I got everything wired up but my problem is that. The vent,hi-low,heat,heat def, and def don't work. I was checking the wires and found out that the functions work if I ground out the wire. That made me think that the climate control was broke so I went a got another one. That didn't help . Has anybody had this problem.
P.s I've checked all the fuses.
The car is a 1989 crx Hf
Thanks
Thanks
What do you have the blk/y wire coming form the crx connected to on the accord climate control?
I know it has to be a ground problem
by the way I dont have the a/c button hooked up on the accord cluster.
Modified by onemore at 11:13 PM 5/10/2008
jasonsjwou
Sep 10, 2006 07:23 PM
