Tail light stuck on?
Car is a 97 Accord LX.
I just diagnosed the problem with the dash lights not coming on from some bad wires next to the AC compressor. Now my problem is my taillights. They will not turn off no matter what. If the car is off, on, running or not, the only way I can get the bulbs to turn off is by removing the bulb. All fuses are good atm also.
I replaced the pedal switch also, and the problem in constant. Any help or input would be greatly appreciated.
Donald
Donald
when you put the new switch in did you think to check the nylon pad that the switch contacts on the pedal assembly? it's cheap and not too hard to put in. it's also a common problem on accords.
check it out.
check it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamark35 »</TD></TR><TR><TD CLASS="quote">when you put the new switch in did you think to check the nylon pad that the switch contacts on the pedal assembly? it's cheap and not too hard to put in. it's also a common problem on accords.
check it out.</TD></TR></TABLE>
LOL!! very true... it happened to me once upon a time.....
Luvshok
Dec 28, 2009 12:57 PM
vteec
May 14, 2003 12:58 PM
