g2_teg_'s For Sale Thread: Fuel System, OEM Honda, B-Series, K-Series, and more!
Old May 10, 2008 | 07:37 AM
g2_teg_'s Avatar
Default g2_teg_'s For Sale Thread: Fuel System, OEM Honda, B-Series, K-Series, and more!
Prices do not include shipping unless they are noted that way.
K-Series stock injectors- $80
These injectors will not work with the stock fuel rail. Only with aftermarket fuel rails. the tabs have been shaved off. they work perfect for a swap with an aftermarket fuel rail.
Fuel System Parts:
Summit 0-60psi Fuel Pressure Guage- $10
This guage works great. just wasnt enough for me. i needed a 0-100psi guage.
-6AN to Banjo fittings- $15
one of them is a hose connection, the other is a -6AN thread connection. let me know what you want.
-8AN to Hose barb fitting- $15
This can be used on a fuel rail with -8AN inlets while using a stock honda fuel line clamped to the hose barb..
Misc fuel fittings- $10/each. (except banjo fitting)
There are two -6AN guage port adapters, a -6AN 45* hose end, an -8AN plug, and a -8AN to -6AN o-ring adapter. i am willing to make a combo deal with these fuel system parts.
Honda OEM Valve Cover Gasket Set- SOLD
Internal Antenna- Sold
OBD2 P75 LS ECU- sold
Ignition Switch and Lock- $40
I have two of these. They are for a 90-93 Acura Integra. They may work for other cars, but i am not sure. These will work if your car has been stolen and recovered and the ignition was broken. Both of them come with keys.
OEM Honda Single DIN Radio Block Off- Sold
OEM Honda 88-91 Civic Antenna Block Off- sold
JDM Type R Oil Cap- Sold
Megan Rear Section- $80 shipped
This came from a 92-95 Civic Hatchback.
Modified by g2_teg_ at 2:35 PM 5/12/2008
Modified by g2_teg_ at 2:37 PM 5/12/2008
Modified by g2_teg_ at 2:39 PM 5/12/2008
Modified by g2_teg_ at 7:16 PM 5/21/2008
Modified by g2_teg_ at 9:40 PM 5/27/2008
Modified by g2_teg_ at 11:14 PM 5/27/2008
Old May 11, 2008 | 03:44 PM
g2_teg_'s Avatar
Default Re: g2_teg_'s For Sale Thread: Fuel System, OEM Honda, B-Series, K-Series, and more! (g2_teg_)
bump
Old May 12, 2008 | 10:36 AM
g2_teg_'s Avatar
Old May 13, 2008 | 12:15 PM
g2_teg_'s Avatar
goin to the O's game, bitches!
Old May 14, 2008 | 11:02 AM
g2_teg_'s Avatar
bump
Old May 15, 2008 | 02:54 PM
g2_teg_'s Avatar
bump
Old May 17, 2008 | 06:05 AM
g2_teg_'s Avatar
ttt
Old May 17, 2008 | 07:13 PM
g2_teg_'s Avatar
bump
Old May 18, 2008 | 07:58 AM
g2_teg_'s Avatar
up
Old May 18, 2008 | 02:49 PM
g2_teg_'s Avatar
O's lost
Old May 19, 2008 | 06:54 PM
g2_teg_'s Avatar
bump
Old May 20, 2008 | 06:03 PM
g2_teg_'s Avatar
How bout them O's?!
Old May 21, 2008 | 03:16 PM
g2_teg_'s Avatar
Old May 22, 2008 | 04:34 AM
g2_teg_'s Avatar
bump
Old May 22, 2008 | 12:44 PM
g2_teg_'s Avatar
got off work early today.
Old May 23, 2008 | 03:19 PM
g2_teg_'s Avatar
bump for a glorious day.
Old May 24, 2008 | 04:30 AM
g2_teg_'s Avatar
bump
Old May 25, 2008 | 06:26 AM
g2_teg_'s Avatar
bump
Old May 26, 2008 | 06:59 PM
g2_teg_'s Avatar
hot today.
Old May 27, 2008 | 02:24 AM
optiquest242's Avatar
PM'd
Old May 27, 2008 | 05:44 AM
g2_teg_'s Avatar
Default Re: (optiquest242)
replied.
Old May 27, 2008 | 05:41 PM
g2_teg_'s Avatar
Old May 27, 2008 | 07:15 PM
g2_teg_'s Avatar
Old May 28, 2008 | 07:57 PM
g2_teg_'s Avatar
bump
Old May 31, 2008 | 06:21 PM
g2_teg_'s Avatar
ttt
