H23VTEC with H22 Mahle 11.5 Compression pistons... = what?
Old May 10, 2008 | 05:50 AM
Turbo EH2's Avatar
* B A N N E D *
Default H23VTEC with H22 Mahle 11.5 Compression pistons... = what?
Mahle rates their pistons for being a straight h22, with the stroke of the h23 crank however that compression ratio should change... So i am wondering what would this combination equal to.. Basically h23 block h23 crank h23 rods with mahle h22 pistons rated at 11.5 compression with an h22 head. Any help would be greatly appreciated!!
87.00 90.00mm 143mm 22mm 31mm 10cc 342g 11.5 H22220425D10
Old May 10, 2008 | 06:25 AM
JDogg's Avatar
Default Re: H23VTEC with H22 Mahle 11.5 Compression pistons... = what? (Turbo EH2)
its going to be close to 13:1 compression
in a standard h22 those pistons are closer to 12:1 than 11.5:1
Old May 13, 2008 | 08:12 AM
white90si's Avatar
Default Re: H23VTEC with H22 Mahle 11.5 Compression pistons... = what? (JDogg)
What about Using there 10.0 CR Mahle Gold Pistons with H23 Rotating Assembly? What CR Then?
Old May 13, 2008 | 09:45 AM
JDogg's Avatar
Default Re: H23VTEC with H22 Mahle 11.5 Compression pistons... = what? (white90si)
the 10:1 pistons are right... 10:1 with an h22 crank, 10.6ish with a 95mm crank
jellyroll
Dec 14, 2006 05:27 PM
tonezilla
Feb 2, 2005 12:20 PM
user 9782082308
Sep 7, 2003 09:40 AM
H23A1LUDE
Jun 12, 2003 04:43 PM
H22Prelude
Nov 17, 2002 08:55 PM
