H22 LMA's in b16 head... any write-up?
easy as hell bro...if the head is off, take out the two rods on the side of the head. Remove the rocker arm assembly. Pull out the B-series LMA's. Then put in the H22 LMA's ***BUT*** you need a certain size washer to put on the bottom before you put the LMA's in. Do a search and you'll find what size to use. Ask Omniman, he had a write up on how to do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">The Prelude LMA's are cheaper. </TD></TR></TABLE>
I remember them being around $7-8/ea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">What is the benefit of doing this?</TD></TR></TABLE>
i guess it helps when using higher lift cams... and cheaper...
