Cam Gear Torque on Skunk2 Pro Series Gears?
Old May 9, 2008 | 06:54 PM
unified112's Avatar
Default Cam Gear Torque on Skunk2 Pro Series Gears?
Just a quick question.. On a '99 Si B16 head, should I torque the bolts to the factory 41ft-lbs torque spec? Or lower/higher due to using Skunk2 Pro Series gears? I was reading about Skunk2 cams and how they recommend using a lower torque rating than oem spec. I know camshafts are different than cam gears, but any opinions will be appreciated. Oh, and the cams are 96+ GSR cams.
Old May 9, 2008 | 07:06 PM
slowtegkauai's Avatar
Default Re: Cam Gear Torque on Skunk2 Pro Series Gears? (unified112)
I would like to know also. I have the same gears but Crower cams on a LS.
Old May 9, 2008 | 07:12 PM
BadWay's Avatar
as long as you are using the stock cams, then use the stock bolt torque. it's the skunk cams that require a different torque
Teamdiesel
16
Sep 3, 2017 08:34 PM
JDM_rolex
10
Nov 18, 2013 05:17 AM
itr_henrik
Nov 2, 2007 08:44 PM
gmacarize
Aug 24, 2007 08:48 AM
na+b18c_hatch
Feb 24, 2007 11:28 AM
