skunk2 ecu?
Old Jul 14, 2002 | 11:01 AM
rocket_R's Avatar
Default skunk2 ecu?
having problem when i use the skunk2 ecu. when i try to start up the car it stalls and would die unless i hold down the gas. is anyone else having this problem? but it's weird cuz it doesn't happen all the time. what can i do to fix this?? i also have a vafc too could this fix it. if so how please explain... to me it seems like theres not enough gas going to it.
Old Jul 27, 2002 | 12:45 AM
sparkz's Avatar
Default Re: skunk2 ecu? (rocket_R)
the chip is probably bad. maybe inserted the wrong way
Old Jul 27, 2002 | 09:28 AM
rainmanEK's Avatar
big strong guy
Default Re: skunk2 ecu? (sparkz)
if chip was bad it would not run! you have same problem most every one else has with that program! its because the skunk ecu does not look for all the sensors! so it wount run like stock, its a race ecu, remeber!!! just live with it! eric
TriiiME3
Jan 20, 2005 01:28 PM
JDM_GSR_131
Sep 19, 2002 05:37 PM
b16aeg
Jul 24, 2002 04:45 AM
rocket_R
Jul 14, 2002 12:44 PM
bananacruzier
Mar 22, 2002 04:34 AM
