evap solenoid sensor?
Old May 9, 2008 | 02:07 PM
emooheo's Avatar
Default evap solenoid sensor?
When i bought my teg the motor had been swapped. It is a 94 gsr w/ a 97 motor in it. I believe it is running obd1 because there is no second 02 sensor. Anyways i went to smog it (CA sucks) and they have to do an EVAP test now. The problem i have no EVAP solenoid sensor cause it was never needed it before.
I was looking at the diagram under the hood and i see where the hoses from the canister go, but i noticed there needs to be a plug that plugs into it. I looked under my hood for about 10 mins and couldnt find a plug anywhere that wasnt connected to something. Can anyone snap a picture of where the plug should be around? like where the wire comes from?
What happens if nothing is plugged into it? Will it fail the test? I believe all it does is check for leaks.
Old May 10, 2008 | 02:00 AM
emooheo's Avatar
Also, i have a skunk2 manifold. It does not have a nipple for the evap solenoid.
Would it be ok to connect a line from the evap to another vacuum line using some sort of nipple connector and just run that to a nipple on the manifold?
jdm_ek_noob
Jan 27, 2014 03:04 AM
StolenTeg
Aug 23, 2006 04:16 PM
Project_EK
Aug 14, 2006 04:25 PM
importlegions
Jan 27, 2005 01:51 PM
