steering damper going crazy.
Old May 9, 2008 | 01:38 PM
crxma22's Avatar
Default steering damper going crazy.
basically i have a gpr damper on my 05 600rr. and it's been on for roughly 4-5 months, it's usually dialed at 5, which is comfortable for me not to stiff not too loose, never had any problems.
well i went to take it for a ride this morning. pulling out my drive way making a left all of a sudden it feels like the handle bars dont' want to turn (lock up) so i put my leg down and bounce back or else i would have dumped it. then it loosens back and i almost fall off to the right... after riding for a bit it goes back to normal . any ideas!? i just don't want to take a corner at a moderate speed and the handle bars loosen and i take a good spill.
Old May 9, 2008 | 01:49 PM
GraphiteAccord's Avatar
Default Re: steering damper going crazy. (crxma22)
some people like GPR's, but I stayed away because they leak, and they also do this. you're not the first. Give a call to them, and they act like it's never happened before. The daytona is getting a Pit bull!
Old May 9, 2008 | 02:02 PM
Sliced Beard's Avatar
Default Re: steering damper going crazy. (GraphiteAccord)
Ohlns is where it is at, a bit pricey, but worth it.
Old May 9, 2008 | 03:07 PM
Tornadom's Avatar
I had good luck with the Ohlins damper on my old bike. I have never used a GPR, so I can't really comment too much on them. In fact, I have never used a rotory style damper, so I am cluless as to why it would do that. It sounds like an internal problem, perhaps a piston sticking or something (I have no cluse how those work, so it may not even have pistons).
Old May 9, 2008 | 06:59 PM
youradhere's Avatar
I think lifesuxdie is the person you want to talk to...
IIRC he has a GPR stabilizer and knows something about them... but i could be wrong =X
Old May 9, 2008 | 07:04 PM
life sux die's Avatar
RIP 1032
Default Re: (youradhere)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youradhere &raquo;</TD></TR><TR><TD CLASS="quote">I think lifesuxdie is the person you want to talk to...
IIRC he has a GPR stabilizer and knows something about them... but i could be wrong =X</TD></TR></TABLE>
i love mine. if you're having problems with it, give them a call and they'll take care of you!!! i sent mine in 'cause it started to leak (my bike sat in the socal sun for a solid year before it started it started to leak), i sent it in and got it back within' 2days free of charge, they even took care of shipping.
Old May 9, 2008 | 07:15 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (life sux die)
The ohlins one is the cheapest, and I mean the long stick one.
The Scotts damper is suppose to be the best, and yes it is made by ohlins, and has on the fly adjustment as does the GPR
Old May 9, 2008 | 10:44 PM
crxma22's Avatar
Default Re: (MugenHonda)
so i checked and i seen a rubber grommet (sp?) pinched against one of the screws and oil was leaking out of it. who knows how long it's been like that. gpr ftl bad bad day....
on a better note, i'll take it back to roseville cycle and hopefully they'll handle it for free since it's been under six moths since they installed it. if not i'll take your advice life's sux die.
Old May 10, 2008 | 08:23 AM
equinox's Avatar
Default Re: (crxma22)
gpr has the best customer service, better than scotts from what i've experienced. Call it in and they'll take care of you. I wouldn't worry about it. I'm glad you managed to save it.
Old Jun 5, 2008 | 11:19 AM
crxma22's Avatar
Default Re: (equinox)
So roseville cycle is going to charge me $136.50 to remove the damper, $13 to ship it to gpr for service then $136.50 to reinstall. $286 total hardly worth it... soooO i'm not exactly mechanically inclined when it comes to bikes. basically i'm just wondering:
1) how hard is it to remove?
2) if i do remove it, will i be able to ride my bike?
3) any precautions i should look out for while installing/reinstalling?
Old Jun 5, 2008 | 11:41 AM
MSchu's Avatar
My Name is Nobody
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">The ohlins one is the cheapest, and I mean the long stick one.
Whaaaaaa.....
Old Jun 5, 2008 | 12:05 PM
Default Re: (MSchu)
here's a quick dislcaimer: I'd never let anyone but a VERY good friend work on my bike. And if you're going to charge me anymore than dinner, then I can do it myself.
That said...the one and only GPR i've ever put on took me 20 minutes...Are you seriously that mechanically inept to not be able to put on and take off 5 bolts? Yes, you can do it yourself, Yes, it's SUPER easy. Cruise 600rr.net, and I'm sure there's more than one how to.
Old Jun 5, 2008 | 12:23 PM
crxma22's Avatar
Default Re: (GraphiteAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">here's a quick dislcaimer: I'd never let anyone but a VERY good friend work on my bike. And if you're going to charge me anymore than dinner, then I can do it myself.
That said...the one and only GPR i've ever put on took me 20 minutes...Are you seriously that mechanically inept to not be able to put on and take off 5 bolts? Yes, you can do it yourself, Yes, it's SUPER easy. Cruise 600rr.net, and I'm sure there's more than one how to. </TD></TR></TABLE>
it looks pretty simple, just didn't want to get in over my head that's all. call it preventative maintenance.. thanks for the input.
Old Jun 5, 2008 | 12:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxma22 &raquo;</TD></TR><TR><TD CLASS="quote">
it looks pretty simple, just didn't want to get in over my head that's all. call it preventative maintenance.. thanks for the input. </TD></TR></TABLE>
You're welcome. Check out 100rr.net also, as that bike can't be much different for the install/uninstall. If you need any help, PM me and I'll give you my phone number, and I have a buddy that can talk you through it.
Old Jun 5, 2008 | 12:44 PM
Slidin'Sidewayz's Avatar
PM me and I'll give you my phone number, and I have a buddy that can talk you through it. </TD></TR></TABLE>
Why would you give him your number if he needs to talk to your buddy? Why cant you just talk him through it..its just 5 bolts you said..
Old Jun 5, 2008 | 12:45 PM
Default Re: (Slidin'Sidewayz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slidin’Sidewayz &raquo;</TD></TR><TR><TD CLASS="quote">
Why would you give him your number if he needs to talk to your buddy? Why cant you just talk him through it..its just 5 bolts you said..</TD></TR></TABLE>
I've never put one on a 600RR, I could do it, but I'd just be using an online guide like he could be. So instead, I have a good friend who loves honda's, and has had every damper made for the 600RR.
Old Jun 5, 2008 | 01:00 PM
crxma22's Avatar
You're welcome. Check out 100rr.net also, as that bike can't be much different for the install/uninstall. If you need any help, PM me and I'll give you my phone number, and I have a buddy that can talk you through it. </TD></TR></TABLE>
alright, i just thought it was a big ordeal, that's why they're trying to charge $136.50. hour 1/2 labor i'll pm you if i run into anything weird.. so the bike is still rideable with the damper off?
Old Jun 5, 2008 | 01:33 PM
slm's Avatar
slm
alright, i just thought it was a big ordeal, that's why they're trying to charge $136.50. hour 1/2 labor i'll pm you if i run into anything weird.. so the bike is still rideable with the damper off? </TD></TR></TABLE>
Yes, you don't need a steering damper to ride. Most people don't have one to begin with. You could always get a rebuild kit for it and save the hassle of shipping it, there not much to them.
Old Jun 8, 2008 | 12:49 PM
X Evan X's Avatar
$135 to remove a damper is highway robbery. The rates they quoted you are insane.
For a mechanically inept person there are more than ample online resources to walk you through removing and reinstalling one. It's much easier than you think.
-E
jhonda239
Honda Motorcycles
22
Mar 6, 2009 02:44 PM
CooBlueDAB
Honda Motorcycles
10
Oct 3, 2005 03:53 PM
Duster
Honda Motorcycles
22
Aug 25, 2005 09:27 PM
JSpecwest
Honda Motorcycles
10
Feb 27, 2002 08:24 AM
