d16a6 head y7 bottom ?
ok so i searched and i cant get a streight awnser
i have a adj cam gear
what timeing belt do i need?
will the valves give me issue? some people said there will be a problem
Do i plug the oil jet in the block ?
and what ARP head bolts ?
Thanks yall
Thanks yall
Y7 is the name of a head(Cylinder Head)
D16 is the block
and the A6 and the Y7 both have a D16 block(Bottom End)
you would need the Y7 timing belt
valves should be fine with the correct timing belt
stock studs work fine you have to use A6/Z6 head bolts
D16 is the block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kay@neighborhoodtrends »</TD></TR><TR><TD CLASS="quote">thank you sir....
any other problems i might run into ?
What about the oil jet ?</TD></TR></TABLE>
I could see that being a problem. Doesn't the Y7 motor have the jet in the head and the A6 has it in the block? I think no jet could spell oil starvation for the head.
silly_mang
Oct 24, 2008 11:43 PM
mck26
Oct 23, 2006 07:07 AM
