FS: Moving!! All Parts Must GO....
JDM H22 w/ Type S Valve Cover, NEW H23 Tensioner Combo, NEW OEM T-Belt, and One-Off AEM Cam Gears. $700.00
H22 Power Steering Pump w/ Bracket and AEM Pulley $40.00
NEW DSS Level 2.9 Axles for H22 in an EK using Hasport Mount Kit $450.00
2003 Acura RSX Type S 6 Speed Trans (Approx. 35,000 miles) No Grinds and always used OEM Honda MTF. $750.00
K Series Starter $85.00
K Series Revo Adjustable Short Throw Shifter $50.00
K Series Valve Cover $45.00
K20 Front Engine Cover $25.00
K20A2 Cams $50.00
K24A4 Oil Pump (Approx. 18,000 Miles) $25.00
K Series Head Bolts (One Use) $20.00 Set
K20A2 Valve Springs $40.00 Set
1996-2000 Civic Type-R or Si-R Power Mirrors (Manual Fold) $200.00
NEW 4 Piston Porsche Calipers w/ Pads and Brackets (I dont know what the brackets fit but custom units can be made to fit your application). $500.00
1997 Honda Civic EX Brake Master $35.00
Test Pipe w/ Cat Heat-Shield (used on a B18C5 Swap on an EK Coupe and may fit others) $50.00
EP3 Type-R Rear Rotors (Fit my EK9 Rear Hubs and may fit others) $40.00 Set
Spearco Intercooler. Brackets on it are made to fit the 1996-2000 Civic. Good for 600 HP $350.00
NEW Spearco Evolution Waste Gate w/ Fittings $200.00
Civic Spare Tire $40.00
1996-1998 (Maybe 99-00) Civic Combo-Switch $40.00
1996-1998 (Maybe 99-00) Civic Ignition Switch $20.00
Picture Coming
1996-1998 (Maybe 99-00) Civic SRS Cable Reel $20.00
HKS "CAMP" System... Came on a car I parted out, I have no clue what it is $50.00
K20A2 Cams $50.00
Picture Coming
formervendor
May 12, 2008 03:22 PM
