FS: Moving!! All Parts Must GO....
Old May 9, 2008 | 08:54 AM
formervendor's Avatar
Banned
Default FS: Moving!! All Parts Must GO....
JDM H22 w/ Type S Valve Cover, NEW H23 Tensioner Combo, NEW OEM T-Belt, and One-Off AEM Cam Gears. $700.00
H22 Power Steering Pump w/ Bracket and AEM Pulley $40.00
NEW DSS Level 2.9 Axles for H22 in an EK using Hasport Mount Kit $450.00
2003 Acura RSX Type S 6 Speed Trans (Approx. 35,000 miles) No Grinds and always used OEM Honda MTF. $750.00
K Series Starter $85.00
K Series Revo Adjustable Short Throw Shifter $50.00
K Series Valve Cover $45.00
K20 Front Engine Cover $25.00
K20A2 Cams $50.00
K24A4 Oil Pump (Approx. 18,000 Miles) $25.00
K Series Head Bolts (One Use) $20.00 Set
K20A2 Valve Springs $40.00 Set
1996-2000 Civic Type-R or Si-R Power Mirrors (Manual Fold) $200.00
NEW 4 Piston Porsche Calipers w/ Pads and Brackets (I dont know what the brackets fit but custom units can be made to fit your application). $500.00
1997 Honda Civic EX Brake Master $35.00
Test Pipe w/ Cat Heat-Shield (used on a B18C5 Swap on an EK Coupe and may fit others) $50.00
EP3 Type-R Rear Rotors (Fit my EK9 Rear Hubs and may fit others) $40.00 Set
Spearco Intercooler. Brackets on it are made to fit the 1996-2000 Civic. Good for 600 HP $350.00
NEW Spearco Evolution Waste Gate w/ Fittings $200.00
Civic Spare Tire $40.00
1996-1998 (Maybe 99-00) Civic Combo-Switch $40.00
1996-1998 (Maybe 99-00) Civic Ignition Switch $20.00
Picture Coming
1996-1998 (Maybe 99-00) Civic SRS Cable Reel $20.00
HKS "CAMP" System... Came on a car I parted out, I have no clue what it is $50.00
Old May 9, 2008 | 09:46 AM
pdiggitydogg's Avatar
http://www.hksusa.com/categories/more.asp?id=1082
CAMP creates digital gauges, when tied into a monitor.
Pretty neat....
Old May 9, 2008 | 10:01 AM
CW-ITR's Avatar
Default Re: FS: Moving!! All Parts Must GO.... (eK24monster)
What size of rims is needed to run with these calipers?
Old May 9, 2008 | 10:12 AM
Banned
Default Re: FS: Moving!! All Parts Must GO.... (CW-ITR)
No clue.
I'd say a kick *** set of 16"s or pretty much any 17"s... Same thing you'd run if you did any big brake/ caliper upgrade... the brackets would ultimately determine the location of the caliper thus affecting the wheel size.
Old May 9, 2008 | 07:30 PM
CAM0FLAG3's Avatar
bump for type-r stufff
Old May 9, 2008 | 09:15 PM
DImages56's Avatar
want the motor..need money first. up for you
Old May 9, 2008 | 10:06 PM
Banned
Default Re: FS: Moving!! All Parts Must GO.... (DImages56)
How much you got? Lets make a deal... I'd really like to use the extra room this could give me on the moving truck.
Old May 10, 2008 | 04:13 AM
DImages56's Avatar
Is it a OBD2 motor? ne thing wrong with it?
Old May 10, 2008 | 08:15 PM
Banned
Looked at the cylinder walls and piston domes w/ a bore scope and everything looks great. The inside of the head as well as the cams look excellent, very little wear shown and no oil stains. I have never started this motor or torn it apart... with the exception of putting the H23 Tensioner, New OEM Belt, and AEM Cam Gears on it.
Note: A Sale is Pending... but money has not changed hands.
Robert~
2mchbst
Nov 16, 2011 06:46 PM
boostinh2x
Dec 24, 2008 06:25 PM
formervendor
May 12, 2008 03:22 PM
formervendor
May 9, 2008 10:34 PM
bb_one
Nov 6, 2006 08:41 PM
