Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
can u tell me the diff
Old May 9, 2008 | 06:54 AM
chode2002's Avatar
Default can u tell me the diff
between 4-2-1 headers and 4-1 headers
Old May 9, 2008 | 10:41 AM
boliver shagnasty's Avatar
Default Re: can u tell me the diff (chode2002)
one is 4-2-1 and the other I think is 4-1 I am not sure tho
Old May 9, 2008 | 10:54 AM
Curiouz_G's Avatar
it might just be me being at work and tired but are you serious? sarcasm eludes me at the moment, just FYI
Old May 9, 2008 | 12:20 PM
HONDURA2K2's Avatar
4-2-1
4-1
Old May 10, 2008 | 07:47 AM
EM2_Kid's Avatar
I'm pretty sure that 4-2-1 headers gives you more power in lower rpms and 4-1 gives you more power in the higher rpms.
Old May 10, 2008 | 09:59 AM
kingSfit's Avatar
Default Re: can u tell me the diff (EM2_Kid)
The 4-2-1 is less free flowing and basically better for torque and lower end power.
The 4-1 is much more free flowing and better for higher end power.
For all-around performance, I guess it will all depend on what your going for.
-As for the different kinds of coatings....it doesnt matter, the coatings dont affect the performance. The ceramic coat looks excellent under the hood ,the stainless steel header also looks great under the hood and due to the constant heating and cooling, the header actually changes colors.
**4-2-1 header will give better all round performance because it will reduce pressure drop in the exhaust tract, however the amount of improvement depends on the rest of the engine, the type of cams used, if they have longer dwell angles as in full race cams then a bigger change over a 4-1 header will be seen
beastman@
Oct 23, 2007 12:02 AM
Fidelio25
Jul 27, 2004 10:15 AM
IntegraGSR321
Sep 30, 2003 06:16 PM
CaMiKaZi
Jun 14, 2003 05:23 PM
jonoknut
Sep 24, 2002 02:27 AM
