big fire problem
Old May 9, 2008 | 04:36 AM
integraturbo96's Avatar
Default big fire problem
Hello
I don't find a trouble on the car of my friend.
The car is 1.6EL( same as a civic with d16y8) 1998
I have no spark and I have changed the dizzy.
No fire and I test each sensor of the dizzy 360ohm so they are good
It have power to the coil and the coil is good.
The fuel pump start and injector have power 12v but after few minutes of cranking the car dont smell gas.
I try 3 ecu and no result. I don't know where to search.
Help me please
Old May 9, 2008 | 05:44 AM
RIZOBIZERT's Avatar
Default Re: big fire problem (integraturbo96)
Is the fuel pump kicking on? If you've verified spark, timing, compression then check for fuel. Make sure the main fuel relay is working. Good luck.
Old May 9, 2008 | 06:48 AM
wonder squirrel's Avatar
Check the rotor to make sure its not damaged.
95PreludeNAed
Jan 10, 2012 04:09 PM
nandito
Nov 9, 2011 08:27 PM
djw19842005
Sep 9, 2009 10:45 PM
bimmeracer
Jul 16, 2008 06:12 PM
QuickTypeR
Nov 23, 2004 08:52 PM
