Window keep blowing fuse
Old May 9, 2008 | 12:41 AM
dcdcdc's Avatar
Default Window keep blowing fuse
My passenger window wasnt workin so i checked the fuse and it was blown. i put another 5 fuses in there and they all blew too. 20amp fuse i was using. any suggestions why and how i can fix this? Driver side works fine.
Old May 9, 2008 | 01:37 PM
Perfectionist's Avatar
Default Re: Window keep blowing fuse (dcdcdc)
Either the window is binding in the track and causing the motor to work too hard, or the brushes in the notor are all carboned up causing the motor to draw too much current, or (if the window doesn't try to move at all) there is a short to ground somewhere.
Old May 9, 2008 | 08:21 PM
dcdcdc's Avatar
Default Re: Window keep blowing fuse (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote"> there is a short to ground somewhere.</TD></TR></TABLE>
like a loose wire or cut wire touching ground?
Tony T
Honda Civic (2001 - 2005)
Jul 11, 2017 11:37 AM
Syke Fu
Oct 7, 2011 10:41 AM
Donkeeyyy
May 29, 2011 08:10 AM
dcdcdc
May 9, 2008 08:23 PM
DFW
Jan 31, 2006 08:26 PM
