Driver window not working on '93 Si.
Old May 8, 2008 | 11:20 PM
socialistic's Avatar
Default Driver window not working on '93 Si.
Where is the power window relay for the driver window??
There's 1 relay...and only the power for the driver window passes through it for the auto-down function. If this relay goes bad, that window stops working altogether. If I can figure out where this relay is...I'm sure that replacing it will fix my problem, but my Chilton's doesn't show relay locations and I've searched this forum and others...even google.
Thanks in advance.
Old May 13, 2008 | 12:20 PM
Still haven't found this relay...anyone know where to find it?
We're going through a lot rain at the moment...and my prelude project is almost ready to hit the streets, can't be letting the rain fk up my new interior.
Old May 13, 2008 | 10:35 PM
Anyone?
Old May 16, 2008 | 03:02 PM
Bump. Still not fixed. Need to find that window relay.
Old May 16, 2008 | 06:05 PM
Acidcrakker's Avatar
Default Re: (socialistic)
Are you 100 percent sure its the Relay, and not the switch, just gone bad.
Just rig it for the time being. Run a power and negative to the wires to jump the switch to see if it goes up and down.
Old May 20, 2008 | 06:12 PM
Still need that relay location. Not getting power to the switch, so it's the relay.
Honda claims they don't even know where it's at.
Anyone know?
Old May 22, 2008 | 03:26 PM
I called Honda again...this time they told me it's plugged in to the top of the fuse panel near all the other relays. They still claim they don't know which relay it is...and that I would have to bring my car to them, fk that.
All the relay does is control the driver window's auto-roll-down feature...and if this relay goes bad, only the driver window will not operate. My driver window is all the way down, and this car is going to be my daily driver within the next week or two...and it's been raining like crazy lately.
Does anyone know where the power window relay is? I've pulled the door panel, tested the switch, tested leads...there's NO power going to the driver window switch meaning there's no power coming from that relay. I need this fixed ASAP.
socialistic
Apr 22, 2008 03:30 PM
alx564
May 17, 2007 07:51 AM
4bangin
Oct 4, 2004 03:44 AM
thehondaguru
Feb 24, 2004 04:20 PM
Leets
Jan 3, 2003 12:13 AM
