Lowering my car AGAIN couple quick ?'s
Okay Ive actually got all the tools this time and I replaced everything I broke last time.....
It should be a clean job.....just curious though.
Im using Skunk 2 lowering springs (they are actually for a 90-93 integra) and they are a 2.25 lowering in the front and 2.5 in the rear......and so of course 2 springs are longer then the others.....the ones that are longer also have a bit of a wider base....they look more like the rear springs doo.....but I would assume the taller spring would go up front since that would be a lesser drop.......and the shorter springs are going to go in the back for the 2.5 drop....
but the shorter springs look more and more like the stock front springs.....
While reinstalling aftermarket springs you shouldnt have to compress them should you since they are lower then stock ones??? I think ill have to compress these????
bo0sted
May 28, 2004 01:45 PM
