how much is to rebuilt a h22A4?
Old May 8, 2008 | 08:22 PM
jbv87's Avatar
Default how much is to rebuilt a h22A4?
im thinkin about doing dat. but i need to kno the price. pz let me kno
Old May 8, 2008 | 08:27 PM
98vtec's Avatar
moderator emeritus
Default Re: how much is to rebuilt a h22A4? (jbv87)
what kinda rebuild?
descriptive details of what you are wanting to do are necessary for answers.
Old May 8, 2008 | 10:10 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbv87 &raquo;</TD></TR><TR><TD CLASS="quote">im thinkin about doing dat. but i need to kno the price. pz let me kno</TD></TR></TABLE>
Wat?
Old May 9, 2008 | 09:57 AM
Panochi Sports's Avatar
I'm looking at the same thing on my 97 SH, I just picked up a JRSC and really want to put it on, but the only problem I have is that my car has about 215,000. If I slap the JRSC, the motor probably going to last only a couple month. So my question is when the most dies, what usually goes out first..? If I was going to rebuild it what should I be looking at to replace, because the SH has a different block it would be expensive to find the motor, and rebuilding the head I THINK would be a better option. Also, a noob question does block last a longtime...?
Old May 9, 2008 | 11:51 AM
jbv87's Avatar
Default Re: how much is to rebuilt a h22A4? (98vtec)
like everything so it can go back to 0 miles
Old May 9, 2008 | 12:14 PM
98vtec's Avatar
moderator emeritus
are you wanting to BUILD the motor with aftermarket parts or do you want to do a stock rebuild?
If just a stock rebuild, go onto a honda online wholesaler and make a list of parts needed and price it out. gaskets, seals, bearings, rings, water pump, oil pump...etc
Old May 9, 2008 | 02:27 PM
smokedyou19's Avatar
If you are goign with FI i would recommend rebuilding the block and head with aftermarket parts. Given the amount of miles you have on your car, i dont believe your car will last long with the supercharger on it. With that being said, the price to rebuild the block could vary depeding on what you do. If you want to sleeve it put new pistions rods bearings etc. the block alone would probably cost 3g's give or take some. If you go with the FI route your always looking at alot of money to get your car running right. You should do some more research before doing anything though.
Old May 9, 2008 | 05:18 PM
ludecz's Avatar
Default Re: how much is to rebuilt a h22A4? (smokedyou19)
I'm currently rebuilding my other H22A1. I post only the basic stuff.
These are only charges by a machine shop :
Jet spray clean block & head ....................................$80
Hone cylinder walls (these were in good shape)...........$50
valves & seats job ( on high milage head you might need some or all valve guides or even new valves, mine was JDM with low miles)............................................ ........................$80
resurface head .................................................. .....$40
And here some of the parts I bought:
ACL maine & rod bearings ( Honda stuff is more of course)
.................................................. ..........................$100
Piston rings OEM............................................... .....$160
Head gasket OEM............................................... .....$75
I don't have all receipts for gaskets but OEM is pricey.
So you'd be in $1000 mostly in parts before you know it. Now if the cilinder walls got deeper scars you will need to spend more money on oversize pistons and boring/honing the wals. The labor depends how much the shop is charging for an hour. I think it would take around 3-4 full working days of labor to pull/install/ assembly the motor.
Modified by ludecz at 8:25 PM 5/9/2008
Old May 9, 2008 | 06:22 PM
DfwBB6's Avatar
going to cost almost $2000 this was full parts and labor including machining and plus 25% off honda parts.
Old May 9, 2008 | 10:16 PM
Default Re: how much is to rebuilt a h22A4? (DfwBB6)
The question is are you going with forced induction... bc if you are dont use oem use aftermarket..It is going to cost alot of money to rebuild entire engine
Old May 10, 2008 | 10:43 AM
If thats the case, then should I just get a Type S motor that would cost about 3 grand. I've done research before and considered going this route, but hearing people telling me that you have to do extensive modification I was afraid to go that way. If anyone with a Type S motor can tell me if it was worth it..? Thanks.!
Old May 10, 2008 | 04:29 PM
Default Re: how much is to rebuilt a h22A4? (Panochi Sports)
Type s IMO is not worth it you can get better aftermarket parts
Old May 13, 2008 | 06:18 PM
gstrudler's Avatar
Yeah, if you've got a working motor already, you can build a better motor for 3G's than what's in the type s. The only major differences performance-wise are the pistons and the cams. AND if you don't have an SH then you have to do some fabbing to get it to work with base model tranny; it's not a straight swap.
Old May 14, 2008 | 01:56 PM
Aright so for the best bang for the buck, I should stick with rebuilding my motor, which I have a SH, what would be an ideal rebuild for JRSC setup..?
Old May 15, 2008 | 08:41 AM
Scheizty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Panochi Sports &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking at the same thing on my 97 SH, I just picked up a JRSC and really want to put it on, but the only problem I have is that my car has about 215,000. If I slap the JRSC, the motor probably going to last only a couple month. So my question is when the most dies, what usually goes out first..? If I was going to rebuild it what should I be looking at to replace, because the SH has a different block it would be expensive to find the motor, and rebuilding the head I THINK would be a better option. Also, a noob question does block last a longtime...? </TD></TR></TABLE>
The SH has an h22a4, just like all the rest.
Old May 15, 2008 | 09:32 AM
Hawkze_2.3's Avatar
Default Re: how much is to rebuilt a h22A4? (Scheizty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scheizty &raquo;</TD></TR><TR><TD CLASS="quote">
The SH has an h22a4, just like all the rest.</TD></TR></TABLE>
Dude, the SH block IS A DIFFERENT CASTING, really. The block is physically different to account for the ATTS unit.
Old May 15, 2008 | 10:17 AM
Saosinx's Avatar
Default Re: how much is to rebuilt a h22A4? (Hawkze_2.3)
Hawkze is dead on.
Old May 18, 2008 | 01:54 PM
Default Re: how much is to rebuilt a h22A4? (Saosinx)
If the SH Block is totally different from the Base model, then I would not be able to get an H22a4 and just swap it out. It would have to be a specific SH motor, or SH Block..? In the case if I were to rebuild my engine what would be the primary parts that fail most on a H22..? and if possible what are the parts that are strong enough that I wouldn't necessarily really need to replace..? Thanks..!
Old May 18, 2008 | 02:48 PM
Hawkze_2.3's Avatar
This is from the Prelude FAQs at the top of the page, it should answer a lot of questions for you:
https://honda-tech.com/zerothread?id=1081801
Old Jun 29, 2012 | 12:29 AM
demin559's Avatar
well it depends if your talking bout time, money or both
Old Jun 29, 2012 | 01:15 AM
jdm_rb20's Avatar
Denim, first of all, Welcome to H-T!
Second, let sleeping dogs lie. This thread is wayyy too old to need any input.
Third, I know you are new, but there is no rush to get your post count up. You have provided some generic no-brainer comments on 5 dinosaur-old-threads.
Post a topic telling us about yourself, your car, your goals, or your questions. We will be glad to get to know you and help you all that we can.
--TJ
jeremyvr6
Sep 30, 2008 12:36 PM
Ultraman
Jan 31, 2007 08:38 AM
unknown2
Aug 14, 2005 01:46 PM
esco72
Apr 2, 2004 09:50 PM
krnboixshawn
Aug 22, 2003 04:36 AM
