not starting might be a problem, help !!
Old May 8, 2008 | 07:08 PM
rsdriver17's Avatar
Default not starting might be a problem, help !!
alright i just put vtec head on and all the wires are connected, i go to start it and it does not wanta fire. It turns over and it getting fuel and spark. I thought it might be my dizzy so i tried my buddys thats has been working and tired it but got the same out come, so we put it back on his and his will not start now, wtf someone please help
(note i checked the engine codes and its just a solid light and i put my stock LS ecu in and it throws o2 sensor which is chipped out on the other ecu)
Old May 8, 2008 | 11:35 PM
rsdriver17's Avatar
Default Re: not starting might be a problem, help !! (rsdriver17)
going to work bump
Old May 9, 2008 | 12:20 AM
jgraham0326's Avatar
does it start with your ls ecu? because a solid cel usually signify's that its a dead ecu. mine just crapped out like 2 days ago so you might wanna check that out. other than that check your main relay, and all your engine grounds. see if any f that stuff helps bro.
Old May 9, 2008 | 12:00 PM
Bjorn20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsdriver17 &raquo;</TD></TR><TR><TD CLASS="quote">alright i just put vtec head on and all the wires are connected, i go to start it and it does not wanta fire. It turns over and it getting fuel and spark. I thought it might be my dizzy so i tried my buddys thats has been working and tired it but got the same out come, so we put it back on his and his will not start now, wtf someone please help
(note i checked the engine codes and its just a solid light and i put my stock LS ecu in and it throws o2 sensor which is chipped out on the other ecu)</TD></TR></TABLE>
Its CRANKING not "turning over" if the engine doesnt run. But anyway, if its getting spark, why would you think to randomly replace the distributor??? If your buddys engine wont start after just doing an R&R on the distributor and no longer starts, one can assume that you messed something up when re-installing it.
spooncivic01
Feb 17, 2008 11:29 AM
silverbur
Feb 5, 2008 01:42 PM
zenon8890
10
Jul 18, 2007 12:25 PM
bare
15
Aug 13, 2005 06:23 PM
Darren
Jul 17, 2005 07:58 PM
