need help with h22 vtech swap
Old May 8, 2008 | 01:35 PM
asianrepnsb's Avatar
Default need help with h22 vtech swap
hey i have a 94 eg coupe and i got a h22vtec swap what do i need to get beside motor mount and axles and what ecu do i use and can i use my wire harness since its obd1 or and any custom work to do for this swap thanks for the help
Old May 9, 2008 | 12:54 PM
Default Re: need help with h22 vtech swap (asianrepnsb)
please someone help
Old May 9, 2008 | 01:03 PM
90hatch94dsm's Avatar
Imgur Lives Matter
search
Old May 9, 2008 | 01:26 PM
hardcore97's Avatar
Default Re: need help with h22 vtech swap (90hatch94dsm)
def do your research on this one. you will need mounts axles, for the ecu you can use a chipped p28 or the prelude ecu. its gonna be a tight fit so def do your research im sure they are some little tricks and stuff you can find
Old May 11, 2008 | 01:42 PM
Default Re: need help with h22 vtech swap (hardcore97)
do you guys know any sites to show me how to convert my car to cable from hydro cause ill the h series are cable transmission
Old May 11, 2008 | 01:58 PM
shadhman's Avatar
The search engine on this site is great but its down for some reason right now. I am planning the same swap and there is literally a step by step walkthrough.. When the search engine comes back up just type in H22 swap and all your answers will be answered . Here is something i found through the stickies for you
https://honda-tech.com/zerothread?id=362984
Dav94Lx
Feb 16, 2008 06:56 AM
quaker
Jan 12, 2004 01:31 PM
hondahatch_nc
Oct 30, 2003 08:42 AM
junglerunna
Dec 2, 2002 10:03 AM
