DA integra obd0 to obd1 distributor adapter
This will work using any oem or aftermarket distributor
Assuming you have aquired a "obd0 to obd1 conversion harness", a obd1 ecu and a obd1 distributor..... this is how to make an adapter to allow your new distributor to work.
For a nicer/cleaner install get your hands on the MALE side of both obd1 distributor plugs(the two wire plug and the 7 wire plug) and the FEMALE side of both obd0 distributor plugs(these are attached to your old distributor).
Now wire the male and female plugs together following this diagram.
when you are done you will have a plug and play adapter for your obd0 to 0bd1 conversion, this will allow you to replace your distributor without cutting wires in the future.
Modified by elmalouno at 3:35 PM 5/8/2008
Modified by elmalouno at 3:44 PM 5/8/2008
this might help you with that...
OBD0 - OBD1 - OBD2 - Function
orange - orange - dark blue - CYPP
white - white - white - CYPG
orange/blue - orange/blue - green - TDCP
white/blue - white/blue - red - TDCG
blue/green - blue/green - yellow - CKPP
blue/yellow - blue/yellow - black - CKPG
large white - yellow/green - yellow/green - ICM
black/yellow - black/yellow - black/yellow - IGN Output
blue - blue - blue - Tach Output
Modified by elmalouno at 5:15 PM 5/8/2008
viking-101
10
Feb 22, 2012 01:46 PM
marc-111
19
Jun 20, 2006 09:40 PM
ej8
Jan 27, 2005 10:56 PM
