i just bought A 98 NEED your help please
hi to everyone i'm a newbie here i just want to know if there is anu good shop in socal (LB / OC) area????? the car that i bought had a major oil leak close to the oil filter i don't know where to be exact but the owner said it has a cracked block...any body has a any suggestions on what should a do..or maybe you can work on the car and i will pay you
cynar
cynar
I also just bought a 98 Prelude (about two months ago). I went to a great dealership in New Braunfels, TX by the name of Randy Adams, Inc. They might be able to help you out.
I've been so happy with my Prelude and they also gave me a great deal. Good luck with the problem!
Schneider
Schneider
thanks guys for the info..i jacked up the car yesterday but did not have time to look for it i will start the car and check where it leaks today...
cynar
cynar
(Hawkze_2.3) yes bro i know???? the block is the last thing in my mind that can cause the leak...
anyway, the owner said it was the block which i don't think.......very nice 1998 prelude with oil leak for $500.00 with 18" 5zigen, greddy catback, AEM intake and needs a paint job...
LOL, its not a cracked block, it's your oil cooler O-ring. The same thing was leaking from my 98 prelude bout a week ago, so I know what i'm talking about, I don't know why, but it seems to be a common problem with preludes.
Double check, could also be your oil filter gasket
The replacement is cheap for both issues; shouldn't run you more than $100 (parts and labor included)
__________________________________
98 Ludester
AEM V2 intake
NGK Wires
Iridium 9 spark plugs
High flow cat
Clear sidemarkers
CCFL Halo projectors coming soon...
98 Ludester
AEM V2 intake
NGK Wires
High flow cat
Clear sidemarkers
ok i went under the car today and looks like it is the round part that the oil cooler goes to and it is on the engine block side and whn i saw it it already had JB weld on it.....but whoever did it did not see where it was leaking found out that it is the oring changed it already and no more leak and running
thanks alot guys
cynar
Modified by sprinter2tg at 5:16 PM 5/12/2008
thanks alot guys
cynar
