ABS light is on...code 1-3 help!!
Old Jul 14, 2002 | 06:48 AM
batboyvaj's Avatar
Default ABS light is on...code 1-3 help!!
leaking outlet valve, leaking relief valve, poor contact in pressure switch circuit. i was retourqing my suspension on my 2001 gsr and my abs light came on and this was the code. someone tell me how to get rid of the light. i already did a search.
Old Jul 14, 2002 | 03:51 PM
batboyvaj's Avatar
Default Re: ABS light is on...code 1-3 help!! (batboyvaj)
comon...somone help....i checked my modulator unit and it was good. and there is a loose connection somewhere?
Old Jul 14, 2002 | 10:01 PM
batboyvaj's Avatar
should i just take it in for warranty...since its a 2001 with 20k mi? but i have all my suspension redone, aem, exhaust. do you think they gonna cover it?
Old Jul 14, 2002 | 10:11 PM
TomO's Avatar
Leng,
Double check your wheel snesors also. I have taken apart my 98 GSR's suspension many times with no problems (crossing fingers). Does the pedal feel spongy? If you still have problems, I can swing by and we can take a look at it. Otherwise the dealer shouldn't have a big problem with it...you can even try to take it to Buerkle Acura in Brooklyn park.
Tom O
Old Jul 15, 2002 | 12:05 PM
batboyvaj's Avatar
Default Re: ABS light is on...code 1-3 help!! (SonicGSR98)
i'm wondering if it was my wheel sensor wouldn't it have given me a diff. code? would bleeding the brakes do anything?
GimmetheLoot
Suspension & Brakes
Feb 11, 2009 06:28 PM
elemntsk8r16
Mar 30, 2008 08:16 AM
DoHcV-tEc
Feb 25, 2008 10:30 PM
dblas
Acura TL, RL & ZDX
Mar 29, 2007 04:23 PM
RHGSR01
Aug 13, 2004 02:45 PM
