Volk, B18c5, 99-00 Si swaybar/LCA, CF hood, tons o parts!
Garage clean out! All civic parts are 96-00 unless otherwise mentioned. I am in Atlanta. Would like to sell big items locally if possible.
Can't seem to link images from Picasa. Pictures are here:
http://picasaweb.google.com/eh...ale02
Volk LE37-Ks w/ center caps. 17 X 7. 5X114. Never seen these on any other car in real life. $1500
205/40 17" Kumho Ecsta MX - Brand new - $275
These are 340 from tirerack BEFORE shipping.
Power steering rack w/ lines. In subframe so easy to swap in. - $100
Power steering pump - $30
Buy with the rack to convert your manual rack civic to PS. I did it. It was AWESOME.
Manual steering rack. Also in subframe - $60
Convert your power steering civic to manual for mad-tyte HP gains. I didn't do it, but I imagine it would be AWESOME.
99-00 Civic Si front swaybar parts. LCAs, forks, swaybar w/ end links - $250
Looked for the above FOREVER. Hard to find...
99-00 Civic Si rear discs w/ emergency brake cables - $150
B18c5 block - bored over to 81.5 on stock sleeves. Disassembled. Probably needs to be sleeved to be safe - $300?
96-00 civic power window conversion parts with door panels, actuators -
Civic AC compressor off 97 civic DX. Worked fine when I pulled it off. Car had 60kish at time of swap - $150
Giant bag of wiring harnesses. Harness from 97 dx, partial harness from 99 civic. Lots of reusable connectors - $50?
90 CRX dx engine with a suspected blown head gasket. Came with the tranny I bought. Chic had a huge adam's apple - $25?
SOLD - 99-00 BKNW carbon fiber hood. Small, 2 inch scratch in it. $100 - SOLD
99-00 OEM Charcoal canister. Brand new, bought it to pass emissions, but ended up not needing it. ph34r.gif Was well over $200 new. You buy it for $100.
Supposed B-series lightweight flywheel. I never used it so I don't know. It came in an ACT box. $50
SOLD - Dented JDM ITR header - $75
99 fuel level sender unit - $20
93-95 RX7 3" Bonez high flow cat. Brand New!! - $375
http://www.rx7.com/store/rx7/fdexhaust.html
That is it for now!
Modified by Ehron at 10:21 AM 5/14/2008
Modified by Ehron at 9:50 AM 5/19/2008
That is it for now!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ehron »</TD></TR><TR><TD CLASS="quote">..... Pending offer on the ITR header; just waiting on the other half of the funds to come through.....</TD></TR></TABLE>"the other half of the funds" is sent
Bump.
Bump.
1fatcrxnem1
Jul 18, 2012 08:51 PM
MRturbo
May 29, 2006 06:41 AM
lilxvtecxpwr
May 15, 2005 07:39 AM
