just did my zc swap but having problems
Old May 7, 2008 | 11:23 PM
b17 turbo's Avatar
Default just did my zc swap but having problems
i just put a dohc zc in my 91 hatch when i connected the batterey it was dead so i jumped it when i was going to start it i noticed the check engine light was on it was dim but it was on and i hadent yet put the key in the ignition so i cranked the car and the motor started evrything was fine then all of a sudden the car died and it smelled burnt inside where the ecu is located on the floor i looked at the ecu i opened it and it looks fine now the car doesnt start it has no spark now any ideas?
Old May 7, 2008 | 11:28 PM
White91EF's Avatar
Default Re: just did my zc swap but having problems (b17 turbo)
check the wires you had to cut at the ecu... maybe they are shorting out? or maybe you just fried your ecu.
Old goat
Jun 30, 2011 04:05 AM
crx5
May 4, 2005 07:31 AM
SiRWannabe
Apr 26, 2003 05:00 PM
chirp2hrd
Feb 23, 2003 03:33 PM
HondaCutie90
Feb 26, 2002 06:08 PM
