loctite
when putting a motor together all the bolts should have loctite on them right?
main studs & nuts
oil pump bolts
water pump bolts
oil pick up and windage tray bolts/nuts
main studs & nuts
oil pump bolts
water pump bolts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993gsrcivic »</TD></TR><TR><TD CLASS="quote">when putting a motor together all the bolts should have loctite on them right?
main studs & nuts
oil pump bolts
water pump bolts
i believe the only bolts that get the slightest bit if loctite are the bolts to hold the flywheel on...right???
main studs & nuts
oil pump bolts
water pump bolts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">Loctite and impact everything down with impact gun on "high"
haha
</TD></TR></TABLE>haha
sig worthy.....
</TD></TR></TABLE>sig worthy.....
deeweewoo
Mar 26, 2005 10:32 PM
