type R exhaust
Old Jul 14, 2002 | 04:31 AM
acuraLSSE95's Avatar
New User
Default type R exhaust
I have a 95 LS, does the 98+ type R stock exhaust bolt right onto my car?
for some reason I heard that ONLY 2001 model GSR exhaust bolts right on to my 95 LS too, is that right?
Old Jul 14, 2002 | 06:59 AM
IC x Prince's Avatar
New User
Default Re: type R exhaust (acuraLSSE95)
95 is obdI...so it might not. Also..the header on a LS I heard is longer so it might...Mine required a little bit of welding. I cut the bottle neck off anyway. so I had them add about 4" to my ITR bpipe. still about 1/2"~1" short but it still fit. Mine is a 94 GSR.
Old Jul 14, 2002 | 07:36 AM
01-0720's Avatar
Default Re: type R exhaust (UltraGSR)
the type r muffler will fit perfect on your ls, ls a type r exhaust are the same lenghth just difrent size piping, gsr an ls/type r exhausts are pretty different in size an a couple things
Old Jul 14, 2002 | 11:38 AM
New User
Default Re: type R exhaust (01-0720)
anyone else agree with 01-0720 about the type R exhaust bolt right onto the 95 LS?
As I was saying, I thought the 2001 model GSR piping was alittle longer than the previous model GSR piping, so If that's the case, does the 01 GSR pipe/mufflr fit onto the 95 LS too?
Old Jul 14, 2002 | 12:26 PM
New User
I agree...that's why I meant that the header on the ITR and LS is the same length, Longer than the GSR. the 2001 piping is shorter, cuz i had that on my car and I had to lengthen the b pipe to reach. the same as my ITR. I believe it has something to do with 94 being obd I smaller cat *shrugs* But it should bolt up, but you have a bottle neck at the flange...I got mine cut off.
Old Jul 14, 2002 | 01:31 PM
b18bfreak's Avatar
I have a type r cat back on my obdI teg.
bolts right up
Old Jul 14, 2002 | 07:19 PM
ITR21's Avatar
Default Re: type R exhaust (b18bfreak)
its a really nice exhaust for b18b's. bolts right up, adds hp, quiet,sleeper.
JDM_wanna_Be
Dec 26, 2007 10:32 AM
g3teg97
May 10, 2006 10:29 AM
rusteds2k
Nov 21, 2003 11:50 AM
DOHCon15s
May 21, 2003 02:10 PM
vtec_addict
May 7, 2002 09:40 AM
