!Help! P30 knock sensor ECU pinout
Old May 7, 2008 | 09:51 PM
BILLisCHILL's Avatar
Default !Help! P30 knock sensor ECU pinout
just swapped a jdm sir2 b16a into my eg and my chassis wasnt wired up knock sensor so its shooting cel 23 knock sensor. i want to wire it myself so how do i go about doing that and where do i wire it to my ecu?
HELP me plz!!!
Old May 8, 2008 | 12:15 AM
stripes777's Avatar
Default Re: !Help! P30 knock sensor ECU pinout (BILLisCHILL)
when i got my swap done, the guy pulled the knock sensor all the way through the firewall and tapped it into the ecu, i would have to get a pic to know which one tho.
Old May 8, 2008 | 08:46 AM
lilo_goki's Avatar
don't waste ur time pulling the knock sensor through the firewall, never done it before and not planning to. knock sensor is piece of cake to wire. it's just a one wire, u wire it from the knock sensor directly to ur ecu on pin d3. you should be able to get a diagram of it, just look around.
Old May 8, 2008 | 05:47 PM
Default Re: (lilo_goki)
thanks i just wired that one wire to d3 on ecu...now the problem is gone thanks
Old May 8, 2008 | 06:40 PM
lilo_goki's Avatar
np. good that it's solve.
jdmem205
Apr 1, 2013 04:10 AM
jdmdseries
Nov 16, 2007 03:46 PM
nub_pwn
Nov 18, 2006 11:48 PM
93NXLUDE
Mar 5, 2003 06:32 PM
