how hard is is it to put 92-95d16z6(ex)motor into my 95 dx sedan 5spd(d16b7)?
Old May 7, 2008 | 07:11 PM
movement01's Avatar
Default how hard is is it to put 92-95d16z6(ex)motor into my 95 dx sedan 5spd(d16b7)?
as I stated above, how hard is is it to put 92-95d16z6(ex)motor into my 95 dx sedan 5spd(d15b7)? and can you guys tell me what part do I exactly need to put these in? any sensors or parts I need to get beside engine itself? please help me. I have 95 civic dx manual transmission. is it hard to do wiring,etc?
Old May 7, 2008 | 07:29 PM
elektronsi's Avatar
Default Re: how hard is is it to put 92-95d16z6(ex)motor into my 95 dx sedan 5spd(d16b7)? (movement01)
i have seen 3 people post nearly the same question today, my advise along with all other H-T user: use the search option and read around a little bit
Old May 7, 2008 | 07:35 PM
JEGD16Z6's Avatar
its not that hard as long as you have all the sensors on the engine and a p28 ur fine. you can use tranny from your d15 if you want and you will have to wire v-tec cuz as far as i know the 95's did not come pre-wired for it and you can use engine harness from ur d15.
Old May 7, 2008 | 07:39 PM
z6hatchboy's Avatar
search. Its a direct swap, wire for vtec and use a p28 ecu.
bka112
May 14, 2007 09:14 PM
b16nonoy
Aug 16, 2006 10:07 AM
nurvcom..
Dec 27, 2004 07:14 PM
