85 prelude custom
ok having some trouble here. Would it be cheaper to put a turbo on my stock 85 1.8 liter carb motor in my lude or swap in a h22a? Let me know what you think please? I desperately need help here!
cheaper to go turbo? you will need an EFI intake manifold of one of hte later accords or preludes such as a A20A,
or better yet, swap hte A20A in and boost that (im pretty sure the A20's are bolt in...)
either way you will need a new fuel system, with a surge tank, EFI pump etc...
BUT the H22A wil be a better engine, not sure it will be a "good" fit, there will be several issues with it.
such as clearance of the hood for starters
anyways, check out my site:
www.geocities.com/b16aprelude
for all the joys associated with a 2nd generation prelude engine swap...
t..
t..
thank you for the post. Maybe a b16a would be a good choice. cheaper than the h22a too. Could you help me if i get a b16a through email. Thanks again, appreciate your input. Have checked out your site many times. Nice work dude>lude man
however, i would strongly recommend more displacement,
eg b18 or b20
both will have clearance issues with the hood, but i am about to find out how much an issue this will be...
defnitly NEED a torquey engine with the slightly heaver Lude...
good luck, make sure you have a clear plan and plently of info, i can help a bit if you need - no problems
t..
eg b18 or b20
t..
