CAR RUNS ROUGH AND ALOT OF WHITE SMOKE, HELP PLEASE!
I JUST SWAPPED A D16Z6 IN MY CAR AND I CANT FIGURE OUT WHY THERE IS ALOT OF WHITE SMOKE AND IT RUNS ROUGH, IT RAN PERFECT WHEN IT WAS PULLED FROM OTHER CAR
check your intake manifold and its gasket. Does it have coolant runing to it? Sometimes if you bolt it on with a weird pattern to torque it doesnt seal properly
please remove your caps lock.
white smoke = coolant
Did you or anyone else touch any internal components between the time frame of taking it out of one vehile and putting it into a different vehicle?
Are you positive you are using the correct computer? Did you touch any wires at all??
Has the car just been sitting for a while before you decided to swap it out?
If you have access to one, put a pressure tester on your radiator and look for any coolant leaks. A **** load of white smoke usually indicates a bad head gasket.
EtherEG93
Sep 17, 2005 08:18 PM
