Swappin a B18b1
So I found a 95 B18b1 Ls motor for my 2000 civic hatch.
The only problem is that it's an obd1 motor and I'm running obd2. Now I've done some searching but haven't found much.
So far I have the phearable Obd2b to Obd1 Harness added to my list, what else am I gonna need when it comes to the wiring. Also I should be able to use the B series mounts except for the rear mount, correct?
Any help would be awesome!
you will need the connectors for the vtec on the motor and have to wire those into the new ecu. The other thing is the mounts you will use all the b series mounts except your drivers side upper mount that the timing belt goes around, Its the same mount on your car as that comes on an 99-00 si. I am in the process of doing a b18c1 motor in my 96 hatch
cesar.151
Apr 24, 2007 02:21 PM
Rratedcivichatch
Jan 4, 2003 01:54 PM
