LS-Vtec Stroker Kit question
So I have decided to go with a Stroker kit for my b18b1. Eagle crank and Rods, SRP Pistons, 11.5:1 Compression. I have been wondering what would be the most agressive cam I could use in this application.
I would like to use the Skunk2 Stage two cams. Any other inputs?
What stroker kit? Whats the final displacement? Stroke length? Bore? What cylinder head? What intake manifold? What header? What exhaust? Is the car a daily? Race only? Weekend warrior? Drag strip? Road Racing? Chocoloate or Vanilla?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">What stroker kit? Whats the final displacement? Stroke length? Bore? What cylinder head? What intake manifold? What header? What exhaust? Is the car a daily? Race only? Weekend warrior? Drag strip? Road Racing? Chocoloate or Vanilla?</TD></TR></TABLE> You always ask such pointless questions he just wanted a lemming response and a thumbs up not if the motor would work or not.
no really as stated you'll need to tell us a lot more then what you did for us to help you.
Well...im looking into the 11.5:1 compression pistons, SRP. The eagle H-beam rods, eagle crank. YADAYADA. Typical Stroker kit. But my question was. Would it be safe to run the skunk2 pro 2's in this setup. as in piston to valve clearance.
Are you mentally handicap?
We have all stated we need to know the engine size, What kind of use will the engine see, how long do you want the build to last, etc. etc. Now you say youre asking about p2v clearance when your original post never mentioned that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990_integra_DA9 »</TD></TR><TR><TD CLASS="quote">are you mentally handicaped? Can you read? I said a B18B1!!!!!</TD></TR></TABLE>
I can read just fine, check it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990_integra_DA9 »</TD></TR><TR><TD CLASS="quote">So I have decided to go with a Stroker kit for my b18b1.</TD></TR></TABLE>
THE TERM STROKER KIT IMPLIES THAT THE ENGINE IS NO LONGER ITS ORIGINAL DISPLACEMENT. JUST STICKING IN AN AFTERMARKET CRANK OF IDENTICAL STROKE OR AFTERMARKET PISTONS OF IDENTICAL BORE DOES NOT MAKE IT A STROKER! Get a clue.
as for the guys whos being nice. Ive never degreed my camshafts. The guy I bought the car from had someone degree them already. I suppose before I actually start the car for the first time. I can crank it over by hand and see if the valves hit the pistons as i crank it over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990_integra_DA9 »</TD></TR><TR><TD CLASS="quote">as for the guys whos being nice. Ive never degreed my camshafts. The guy I bought the car from had someone degree them already. I suppose before I actually start the car for the first time. I can crank it over by hand and see if the valves hit the pistons as i crank it over.</TD></TR></TABLE>
You do that.And when you realize the point of minimum clearance is in VTEC, and that you need to lock the cams in VTEC for this to even come close to being an acceptable method, you can go ahead and take the car to someone who knows what they are doing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990_integra_DA9 »</TD></TR><TR><TD CLASS="quote">I SAID LSVTEC!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! im pretty sure i did at least.</TD></TR></TABLE>
YOU SAID STROKER. If you want/need help with very technical subjects you need to provide technical info, not just words you have read in Import Tuner.
thats why im on here asking if someone has ever done this before. Because I dont want something bad to happen. thank you very much. thats the point of honda-tech. to help people who need help...not to make people feel dumb. like your doing.
First of all, you bumped your own post 3 times within a 4 hour period of posting. Thats annoying. Second of all, no one probably responded in those first 4 hours because your post was so vague no one could answer the question. At least if I make you feel like an idiot, you will remember the lesson. If I spoon feed you the answer, you will continue posting like an idiot, which is detrimental to this board.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990_integra_DA9 »</TD></TR><TR><TD CLASS="quote">the main topic on this forum is LS-vtec stroker question.</TD></TR></TABLE>
Sheebus, you just dont get it, do you. So what would an LS/VTEC be with 95mm EAGLE crank? Would it still be an 1.8 liter? A 95x81 will want different cam timing than a 81x89. But since youre obviously right, and I am obviously wrong, I will stop posting in this thread.
Holy cow why dont you go through this thread at least before you do anything with the car/engine. reading is your friend.
https://honda-tech.com/zerothread/1676914
Modified by EatSleepJDM at 8:17 PM 5/8/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990_integra_DA9 »</TD></TR><TR><TD CLASS="quote">if your going to give me advice then id be more then welcome to continue this thread.
How are we suppose to give you any advice if you have not provided us with sufficient information about your build? You claim your motor to have stroker kit, but you cant assume us to know the parameters around your build..is it a 92mm or 95mm crank? what bore? what R/S ratio?
I am pretty sure that it is the 95mm crank. with the 11.5:1 Compression ratio. Bore is stock 81mm. Perameters...daily driver with the ablitily to beat on it whenever as well as a weekend runner.
This like like watching a train smash into your moms car as she's baby sitting your new born son, only this time it's not an insurance scam and you really are sad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990_integra_DA9 »</TD></TR><TR><TD CLASS="quote">I am pretty sure that it is the 95mm crank. with the 11.5:1 Compression ratio. Bore is stock 81mm. Perameters...daily driver with the ablitily to beat on it whenever as well as a weekend runner.</TD></TR></TABLE>
Skunk2 Pro 3's
Skunk2 Pro 3's
