CTR Pistons Into B16
Old May 7, 2008 | 02:43 PM
ej1252's Avatar
Default CTR Pistons Into B16
i blew my pr3 piston rings and have ctr pistons laying around.
i wanna know if theres gonna be any piston to valve clearence problems? im pretty sure no but doesn hurt to ask.
its a stock b16 stock head, no machine work, no milling, stock block and the walls dont need honing.
Modified by ej1252 at 3:51 PM 5/7/2008
Old May 7, 2008 | 03:06 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: CTR Pistons Into B16 (ej1252)
You should be fine. Those piston's were designed to be used in a B16 anyway. I know the B16b block has a 7mm deck height difference, you still shouldn't have a problem. People run them in there 89.2mm LS/VTEC's no problem.
According to C-Speed racing, with a 3 layer Oem headgasket your compression is gonna be right around 11:1.
Hope that helps!
Old May 7, 2008 | 03:26 PM
ej1252's Avatar
Default Re: CTR Pistons Into B16 (emotionisdead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emotionisdead &raquo;</TD></TR><TR><TD CLASS="quote">You should be fine. Those piston's were designed to be used in a B16 anyway. I know the B16b block has a 7mm deck height difference, you still shouldn't have a problem. People run them in there 89.2mm LS/VTEC's no problem.
Hope that helps! </TD></TR></TABLE>
great thanks alot...thread done with
vtec-power
Nov 7, 2010 07:44 AM
GetawayInMoscow
Oct 27, 2006 09:17 AM
chocolatecivic
Jun 23, 2006 06:23 PM
hb4u2nv
Jun 11, 2004 12:23 PM
