H22A Civic Prelude Turbo Ramhorn Mounts AEM Avid Fluidampr Sleeved Block JE Pistons Built Head, Ever
I regret to say that I’m getting out of the import scene…. That being said I’ve got a couple years of parts gathered up…
I’ve used the descriptions of the people that I’ve bought this stuff from since I have not had the opportunity to use most of it. I will be as honest as possible with all the parts that I have and let you know anything that I know. I'm sick of People Screwing me over so I have no intention to screw anyone else over.
Please respect what I have and don’t low ball me or downgrade me without consulting with me first. If you have no intention on buying please don't waste my time or yours.
Paypal Accepted for payment, No Trades.
Most Pictures can be found at:
http://s301.photobucket.com/al...t=all
http://s301.photobucket.com/al...=grid
3” Stainless Steel V-Band Clamp and 2 flanges
3” to 2.5” 90degree reducing elbow
99-00 Civic OEM Headlights with Eyebrows
99 GSR Rear Lower Control Arms
H22A Prelude Power Steering Pump – Came with swap I’ve never used
H22A Prelude A/C Compressor – Came with swap I’ve never used
ACL Race H22A4 Main Rod Bearings – std NIB $40
H22A Eagle Rods w/ ARP Bolts – Used $250
H22A Aluminum A/C Bracket $30
H22A ARP Main Studs – NIB $75
Avid Racing Aluminum Engine Mounts for H22A into 96-00 Civic – Brand New $230
H22A Bear Engine Block w/ Main Caps, needs sleeves
Borg Warner S362NET with Oil Inlet & Drain Flanges – Brand New bought from The Turbo Trader, missing bolts to hold on 1 oil flange (2 - M8x1.25 bolts) $790 Shipped
CBR 929RR Coils with Pigtails (Used for Coil on Plug setups) $65
CBR 929RR Coils (Used for Coil on Plug Setups) $62
Chrome Oil Cap (High Quality Screw in type) $30
H22A Complete Gasket Kit $75
OEM Honda Plugs for screwing into the back of the block $20
TD61U Distributor $60
H22A Stock Complete Head & Valve Cover, just back from machine shop & all Checked OK
GM Boost Control Solenoid – Brand New
H22A OEM Crankshaft 92-96 50mm Mains – Excellent used condition $170
H22A Closed Deck Darton Sleeved Block (50mm Mains 87mm Bore), Used (2 of the bell housing bolt holes are stripped as well as 2 oil pan stud holes, apart from that I’ve never used this block but I bought it used, bare block but includes main girdle) Apparently used for 800 miles. $550
Infinity Q45 Throttle Bodies, Sold as pair $120
DSM 450cc Injectors $80
H22A JDM Complete Intake Manifold (Less injectors, fuel rail attachments) and includes EGR Blockoff, TPS Sensor Has damage to clip but is still useable if need be.
XP Power Intercooler, relatively small size but supposed to be able to support 1000whp, take off a few b/c it’s xspower and should have no problems with 600whp. 2.5” inlet and outlet on same side allows you to retain your factor windshield washer bottle. $150
H22A JDM LSD Transmission M2B4, Shifts flawless and no grinds, could use a much needed cleaning $800
H22A JE Pistons 87mm bore; 9.1:1 Compression includes 3 good eagle rods and part of another that obviously spun a rod bearing. Apparently used for 800 miles. $350
Jackson Racing oil Cooler Kit – Brand New $240
MSD DIS-2 High Output PN# 62111 – puts out way more power then a standard MSD DIS-2, The HO models produce an incredible 170 milliJoules of spark energy $280
http://www.msdignition.com/sci_5.htm
OBX H22A – Venom Style, Intake Manifold – Brand New $140
OBX H22A LSD w/ repair kit (bolts & washers), if you’re interested I’ll send some pictures of the gears that have sustained some damage (Compliments of Gotboosthatch, or his brother…) still be good to go with a little bit of cleanup. $200.00
H22A OEM Valve Cover Gasket – Brand New
Place Racing H22A Civic Rear Mount
Reactive Shift Boot Kit, I have about 8 of these. $25
H22A Seco Stock replacement Clutch
H22A Head just came off Block above that needs sleeves (Ringlands on pistons went)
H22A STR Competition Fuel Rail, what you see is what you get, I wasn’t shipped extra connections $65
H22A STR Turbo Manifold used 1.5 years $100
STR 45-48mm Wastegate Relocation Accessories $30
H22A Insulating Intake Gasket
Thermo Tec Turbo Insulating Kit (Large) PN # 14001 Complete Kit – Brand New $75
H22A Toga Racing HP Main Bearings – PN # MPH20-HP-std for 50mm Mains – Brand New $50
Other parts for sale:
( May be viewed at http://www.cardomain.com/ride/361667 )
H22A Aluminum Oil Pan – Used
H22A Steel Oil Pan w/ Turbo Drain
Enjo EM96 Mount Kit 96-00 Civic w/ H22A – Used and needs a good cleaning
XsPower Intercooler 2.5” opposite side Inlet & Outlet $110
H22A Shift Linkage and Brackets w/ Short Shifter Attachment $90
SSQV Blowoff Valve, Generic copy of HKS used $50
XPPower Wastegate 38mm, Generic used $50
2.5” Stainless Steel Intercooler Tubing & Connectors
H22A Fidanza Cam Gears (Silver) – Used $100
H22A Timing Belt Manual Tensioner Conversion w/ Timing Belt and Balance Shaft Belt used for 2 years (Apx 10K Miles)
Devils Own Stage 2 Progressive Alcohol Injection Kit for use with GM 3 Bar Map sensor or similar - NIB $290 Shipped
Autometer Sportcomp Boost gauge (Mechanical full sweep black face w/ silver trim) - used
Autometer Sportcomp Oil Pressure gauge (Mechanical full sweep black face w/ silver trim) - used
Autometer Sportcomp Oil Temp gauge (Mechanical full sweep black face w/ silver trim) - used
KaizenSpeed Balance Shaft Elimination Kit – Brand New - Sold to Jordon
Oil Filter Relocation Kit w/ 2 access Ports (I had 1 used for the Turbo feed and the other for the Oil Pressure sender) sold to CRX-si
AEM Wideband UEGO Gauge Kit - Used - Sold to CRX-si
Holset Turbo, used for Approximately 40K miles and replaced b/c of “sticking” waste gate, No shaft play, HE351CW, T3 Flanged - Sold to netrisk032
GM 3 Bar Map Sensor w/ Pigtail – Brand New - Sold to netrisk032
AEM EMS 30-1040 – Used Sold to magefa
Drive Shaft Shop Stage 5 800whp Axles H22A Civic complete with Hubs & ARP Extended Wheel Studs already mounted with brand new wheel bearings & Ball Joints – Used for mock up only . (fits 88-91, 92-95, and 96-00 Civic & 1994-2001 Integra w/ Large wheel bearing Diameters) (missing 1 washer that’s supposed to be there with Wheel Nut, and small pinhole in outer boot next to clamp {I can send more detailed pictures but is a simple repair}) Sold to ozzyman
Drive Shaft Shop Level 3.9 600whp Axles - HY51 H22A Civic (fits 88-91, 92-95, and 96-00 Civic & 1994-2001 Integra w/ Small wheel bearing Diameters) Includes Hubs & ARP Extended wheel Studs – Used for mock up only Sold to jared50438
ACL Race H22A Rod Bearings – std NIB Sold to rebo0t
ACL Race H22A Thrust Washer – std NIB Sold to rebo0t
H22A Fluidampr Harmonic Dampers Harmonic Balancer Part # 730602, Alternator Only – Brand New Sold to rebo0t
H22A Toga Racing HP High Volume Oil Pump, supposedly carries a 1 year warranty on engines up to 800hp – Brand New Sold to rebo0t
H22A OEM Crank Pulley – Used Sold to CivicVelox17
H22A ARP Head Studs – Used Sold to Varano44
Delphi 1000cc Injectors Used Sold to Varano44
H22A Fidanza 8lbs Flywheel – NIB Sold to Varano44
H22A SP RamHorn Turbo Manifold w/ modified alternator bracket, Coated and flange CNC’d to reduce heat while maintaining maximum strength – Used Sold to Varano44
H22A Built Head, P&P intake passages, Skunk 2 Turbo Cam’s (S7 & S9 Carved in cam ends), Ferrera Valves, Ferrera Double Valve Springs, Ferrera Retainers. Used Sold to Varano44
H22A Wiseco Head Gasket – Supposedly same as Cometic – New Sold to Varano44
H22A XTD Racing 6 Puck Clutch – Used Varano44
OBX Fuel Filter – AEM Knockoff – Brand New Sold to Neil
Modified by rossc96 at 8:38 AM 6/10/2008
Modified by rossc96 at 1:04 PM 6/18/2008
