T6 Divided Collector
Old May 7, 2008 | 11:32 AM
Justin Olson's Avatar
Default T6 Divided Collector
Received my 6-2 T6 collector the other day. It turned out ok. I'm going to need to massage it a bit before welding up the manifold. I just wanted to show you guys what it looks like. SLS did the collector and flange for me.
Regards,
Justin
Old May 7, 2008 | 12:07 PM
HPP's Avatar
HPP
Looks nice. Can I ask how much they charge for that? And I assume the T6 flange is Mild steel?
Old May 7, 2008 | 02:38 PM
weiRtech's Avatar
OG Fabricator
as far as collectors go, i don't think you will find them cheaper.
damn, that is one big turbo.
Old May 7, 2008 | 02:47 PM
Smokinsax's Avatar
The Boot
Default Re: (weiRtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">
damn, that is one big turbo.</TD></TR></TABLE>and thats not a tiny collector either.
Old May 7, 2008 | 03:13 PM
PSI2HI's Avatar
Former Vendor
Yeah, i'd put an angle @ the base so it makes getting in there and welding easier. Left them flat on the bottom so you could fit them up as you wanted.
Old May 7, 2008 | 04:14 PM
manifoldmiketyson's Avatar
Default Re: (PSI2HI)
i wouldn't put anything less then 10 degrees between the two merges. its a bitch to get in there.
looks good though. i just got a t6 divided flange in today. i'll be making the collector for it in the next couple days.
what turbo is that?
Old May 7, 2008 | 04:17 PM
Default Re: (manifoldmiketyson)
Its a Borg Warner S480 W/ the Race compressor cover. Its from Dave @ Majestic. Best Deals around on these BW turbos I've found. I bought this one from a friend of mine who bought it from Dave, but decided to go bigger. I payed $925 for the turbo new in box.
Justin
Old May 7, 2008 | 04:24 PM
PSI2HI's Avatar
Former Vendor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manifoldmiketyson &raquo;</TD></TR><TR><TD CLASS="quote">i wouldn't put anything less then 10 degrees between the two merges. its a bitch to get in there.
what turbo is that?</TD></TR></TABLE>
Weld as far as you can then finish whats missed on the inside, makes life much easier.
Old May 7, 2008 | 04:25 PM
Yeah, the T6 divided flange is big enough I'm just planning on welding it up on the inside completely. I really need to work on mocking up the turbo and engine soon.
Regards,
Justin
Old May 7, 2008 | 11:33 PM
HPP's Avatar
HPP
Default Re: (Justin Olson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson &raquo;</TD></TR><TR><TD CLASS="quote">Its a Borg Warner S480 W/ the Race compressor cover. Its from Dave @ Majestic. Best Deals around on these BW turbos I've found. I bought this one from a friend of mine who bought it from Dave, but decided to go bigger. I payed $925 for the turbo new in box.
Justin</TD></TR></TABLE>
WoW! Thats cheap! What exhaust wheel and a/r?
Modified by -RedneckDave- at 6:49 AM 5/8/2008
Old May 8, 2008 | 04:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, the T6 divided flange is big enough I'm just planning on welding it up on the inside completely. I really need to work on mocking up the turbo and engine soon.
Regards,
your going 2jz-ge right? you eliminating the distributor?
i'm going with a s380 for my setup.
Old May 8, 2008 | 10:12 AM
.RTErnie's Avatar
i'm going with a s380 for my setup.</TD></TR></TABLE>
oh yeah....well....Im going do a neon so ha! lol I hate you guys.
&lt;-- 2JZ envy
Old May 8, 2008 | 10:33 AM
Default Re: (.RTErnie)
Yeah,
I'm doing a 2JZGE w/ AEM and a cam gear trigger for engine position like Tony1 sells for honda's.
Regards,
Justin
Old May 8, 2008 | 10:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">
&lt;-- 2JZ envy </TD></TR></TABLE>
2JZGE's are cheap and fun. I really like my project thus far
Justin
Old May 8, 2008 | 02:56 PM
check this out
http://www.supraforums.com/for...89826
i'm panning on running a tec3r on batch. i don't really give a crap about sequential. not to mention i'm running 450cc primaries and 1600cc secondaries.
i was looking into possibly doing a cam trigger too, but after looking at it, there really isn't a good place to build a bracket off of.
i also heard you can run a cam trigger off of a 7m that will bolt into the dizzy hole without the huge aparatus.
i'm asuming your running a tt oil pump and crank trigger?
2jz-ge is cheap as ****. stock bottom will hold over 800 with a 2mm headgasket and studs. only problem is that stupid dizzy.
Old May 8, 2008 | 03:16 PM
qksl2's Avatar
I personally like the distributor.
I just tuned a car today at 28lbs on pump + meth. Picked up a tiny bit of knock... easily fixed by a slight **** of the distributor.
No blowout with 6097's at .028. ;-)
Ian
Old May 8, 2008 | 03:34 PM
The 12+1 cam trigger is all I need to run for sequential AFAIK. I will be running 12 of the equally spaced magnets all in same orientation. Then there is 1 magnet placed between two of the 12 that has an opposite orientation. You use a dual poll hall effect sensor and this gives you both crank position and sinc signal.
Currently I'm not planning on running the TT crank trigger or oil pump.
Regards,
Justin
Old May 8, 2008 | 04:37 PM
This is how DaveH mounted his dual poll hall sensor on his 2JZGE racecar.
Justin
Old May 8, 2008 | 07:18 PM
never figured to put it behind. derrrrr....
thats a pretty bad *** setup.
you going to use the tt aem box? universal?
Old May 8, 2008 | 07:28 PM
I'm using the AEM 30-1050 honda box. It has the most I/O and doesn't have the funky drivers like the TT box.
Justin
Old May 13, 2008 | 11:05 PM
carchitect's Avatar
Guys If you're planning on running an AEM box on the supra. Use the VVT-i ignition coils and wires for the 3-channel waste spark system. The TT 6-channel coils are great if your ignition system is 6-channel sequential. Which I think the Motec is the only one capable of doing so for you.
Old May 14, 2008 | 11:00 AM
Default Re: (carchitect)
I'm going to run the TT coils with AEM and a M&W Pro14 box. I plan on running wastespark with this setup. The CDI igntion should be plenty powerful for my needs.
Justin
Old May 14, 2008 | 03:54 PM
PharcydeH23's Avatar
** RESTRICTED **
Nice
Old May 17, 2008 | 06:38 AM
Default Re: (PharcydeH23)
any progress?
i ordered my turbo yesterday. s480, race cover with 87mm turbine and 1.10 turbine. guess i'm jumping on the band wagon
i'm supposed to be getting a gt4788 in the next couple days too, so i'll post pics in another thread about similarities and size.
Old May 17, 2008 | 10:43 AM
kings_blend's Avatar
Very impressive. I like your cam gear setup. Im working on a 1jz swap in a 240sx using the AEM 1600 series box for the ka. Ill be using LS1 coils in wasted spark as well. Nice to see someone get so creative. bets of luck to you! Just wondering what transmission and clutch setup your going to use. Im thinking about building my own push type clutch for the r154.
