Right turn signal dont work and its not the bulb(Help!!!!!!!1
Old May 7, 2008 | 09:49 AM
99delsol's Avatar
Default Turn signals dont work and its not the bulb Please Help!!!!!!!
I have a 98 prelude and the both front and back turn signals dont work.When i hit the hazards no signals.Its not the bulbs either.What about the fuse.Which fuse is it.I couldnt find it.I appreciate all help.Thanks
Modified by 99delsol at 3:27 PM 5/7/2008
Modified by 99delsol at 12:09 PM 5/8/2008
Modified by 99delsol at 12:10 PM 5/8/2008
Old May 7, 2008 | 10:35 AM
mattsnooz's Avatar
Default Re: Right turn signal dont work and its not the bulb(Help!!!!!!!1 (99delsol)
Not a fuse. Its a wiring issue.
Your turn signals ( Im 99% sure) are all on one fuse. If your rights weren't working than neither would your lefts.
Turn your signal on, and using a multimeter on DC voltage measure the voltage accross both sides of the light bulb lamp holder. If you don't get voltage (it will be +12, 0, +12, 0, as it flashes ( I think they are 12V) than wiring is your problem.
Does your signal arm function normally? Also, do you see the signal pop up on your heads up display (cluster)? (green flashing arrows with the sound affects)
Old May 7, 2008 | 11:17 AM
99delsol's Avatar
Actually all the turn signals dont work or when i hit the emergency button there no signals or signal in the gauge cluster.So would it be the fuse ?If so what fuse?(location/Number).Thanks
Old May 16, 2008 | 06:50 AM
99delsol's Avatar
No one?Where can i find the fuse and which one is it?
Old May 16, 2008 | 10:09 AM
mattsnooz's Avatar
Default Re: (99delsol)
For a 4th gen there are two. Driver side, down by your left shin. Its a black cover that opens by rotating a circle latch.
The second is in engine bay passanger side, (top left corner when looking at motor). I hope its the same for 5th gen.
If your replacing fuses, use proper values, and don't ever over size them or put jumper wires in. If there is a short you need to find it and fix it period.
Good luck
Old May 20, 2008 | 08:59 AM
99delsol's Avatar
Thanks for the reply.But which fuse is it?It doesnt say for signals.
Old May 20, 2008 | 09:47 AM
Hawkze_2.3's Avatar
Could also be your flasher relay, that's what controls all the signals and how they flash.
Old May 20, 2008 | 02:36 PM
Fongman's Avatar
if you hazards don't work, you turn will not work. they are one system. sounds like fuse, but i would check that 1st and the hazards switch. one last thing are you sure you have bulb lights?
Old May 22, 2008 | 09:13 AM
99delsol's Avatar
Yes i have light bulbs and they all work.Can you guys tell me which fuse it is?What is it labeled as?Thanks
Old May 23, 2008 | 10:01 AM
99delsol's Avatar
anyone?
greeen ranger
Lighting
Aug 20, 2013 08:44 PM
Tito559
Jan 30, 2011 08:24 PM
JDM Lyfestyle
Feb 26, 2009 08:14 PM
Matt_2078
16
Oct 20, 2005 09:01 PM
moleodonuts
Sep 13, 2005 02:00 PM
