will BB6 5Lug Suspension work on 92-95 civic
Old May 7, 2008 | 07:24 AM
Nurvcom's Avatar
Default will BB6 5Lug Suspension work on 92-95 civic
ok what i need to know anyone out has got to know 100% on this
Will prelude rear hubs and rotors work on my GSR rear disk brakes ? I seen some saying it will just need it confirmed if so i going to get the cross drilled ones at the junk yard asap lmk
it BB6 5LUG Suspension and the car it going on is 95 civic coupe EX
lmk
thanks
Modified by Nurvcom at 8:21 PM 5/9/2008
Old May 7, 2008 | 07:42 AM
v4lu3s's Avatar
RTFM
im sure if properly ghetto engineered it could be bolted up to the car. as far as safe to drive...I would not put any money on it.
its not as if the knuckles are not considerably longer on the lude than the civic.
Old May 7, 2008 | 07:46 AM
md23vtec's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">im sure if properly ghetto engineered it could be bolted up to the car. as far as safe to drive...I would not put any money on it.
its not as if the knuckles are not considerably longer on the lude than the civic.</TD></TR></TABLE>
Correct! To the OP Look into the ITR 5 lug swap. Safe and 100X easier to complete and your alignment specs will thank you for it
Old May 7, 2008 | 08:16 AM
Nurvcom's Avatar
Default Re: (md23vtec)
ya true ..... some one of my friends said the rear suspension from prelude would have to be pressed onto my civic rear disk...
and i just found a small ppart of info about front someone says CRV with b20 and 5lug is same as ITR front suspension
Old May 9, 2008 | 07:20 PM
Nurvcom's Avatar
Default Re: (Nurvcom)
Old May 9, 2008 | 09:23 PM
Nurvcom's Avatar
Default Re: will BB6 5Lug Suspension work on 92-95 civic (Nurvcom)
if i can use the prelude rear hub what other stuff do i need other than rotors do i need calipers to???
Lasty K
Suspension & Brakes
Dec 17, 2006 08:07 AM
boostngsr
Dec 12, 2004 02:19 PM
Ace00
Jun 25, 2004 04:23 PM
jeffk182
Apr 27, 2004 09:50 PM
Robb
Dec 29, 2003 09:31 AM
