Check engine light issue!!!
hey guys,
i have a very weird problem with a check engine light. car is a 95 honda civic cx. it has a b16a3 engine (i cant remember what ecu).. I start the car and after 5 to 6 seconds of running the engine light comes on. so i turn off the engine and trip the system. put it on the on position there is no engine light. only comes on when the engine is running. any suggestion i will appreciate it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baulum »</TD></TR><TR><TD CLASS="quote">Have you tried to see what code is it throwing?</TD></TR></TABLE>
x2 check what code it is
this could be something as simple as ur gas cap....cuz dats what it sounds like, if it only happens when ur running ur car....do u have an oem cap?? if so, check to c if it's still good....but before buying a new one definately check what code ur ecu is throwin.....p.s. only buy an oem gas cap....the auto zone ones r ****!!
That is the problem. when i turn off the car then put it at the on position the engine light isnt on. i havent check my gas cap. i will tho. any other possibilities.
The engine light comes on when the engine is running for 5 to 6 sec. but i turn the engine off. put it at the on position and no engine light.
