Suspension Upgrade
Hey wsup.
I am going to buy new suspension for my 90 crx si.
I am looking at this combo they got on PROSTREETONLINE DOT COM.
It is the KYB adjustable shocks with Tein Stech springs or
Tokico 5 way with tein Stech springs.
Anybody got any other ideas i should go with?
And while im doing the suspension is their anything else i should change like
camber kits, bushings, control arms etc. ? let me know thanks!
The best bang for the buck is the Koni Yellow and Ground Control coil over setup. It would be a good idea to replace the bushings while your down there but replace them with OEM busings. Control arms aren't needed. Camber kit would be a good idea. I would also recommend the Suspension Technique 22mm sway bar. Search around a little and you'll see alot of threads about the Koni/GC setup. Good Luck.
Stunna BEN
85
May 14, 2004 11:50 AM
