AEM Cam Gear Install on 5th gen
Old May 6, 2008 | 07:15 PM
Toanz's Avatar
Default AEM Cam Gear Install on 5th gen
So while i was doing my timing belt, i decided to install a set of aem cam gears i had laying around for awhile now.
As i took off the stock cam gears, i noticed that there was a slot in the camshaft
that lines up the cam gear. The key the slides into that groove on the camshaft
is part of the cam gear.
Now the problem is, the aem cam gears isnt like that stock ones, its missing
the keys, and i can use the stock ones, cause they're part of the stock cam gears.
Am I suppose to get them off another vehicle?
Any help would be appreciated.
Thanks
Old May 6, 2008 | 07:21 PM
Hawkze_2.3's Avatar
Default Re: AEM Cam Gear Install on 5th gen (Toanz)
4th gens have separate keys, you should be able to order some of those from Honda.
Old May 6, 2008 | 08:11 PM
A Blue Lude's Avatar
Default Re: AEM Cam Gear Install on 5th gen (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">4th gens have separate keys, you should be able to order some of those from Honda.</TD></TR></TABLE>
Yep.
Old May 7, 2008 | 05:37 PM
Seroga415's Avatar
Mistake 1:
AEM CAM gears are pointless
Old May 7, 2008 | 07:28 PM
Toanz's Avatar
Default Re: AEM Cam Gear Install on 5th gen (Seroga415)
and why would you say that?
You dont even know why I'm using them?
I got them because im going FI and using them to help eliminate overlap.
$100 for cam gears, why not.
Old May 9, 2008 | 02:16 AM
Seroga415's Avatar
for that reason ok i guess, but if u want some cam gears that give u more power via acceleration, go edelbrock or fidanza
Old May 9, 2008 | 03:29 AM
no1knows908's Avatar
I have never looked at after market cam gears as "light weight" to reduce rotational mass... The only reason I would purchase cam gears it for fine tuning cam timing.
Old May 9, 2008 | 08:28 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seroga415 &raquo;</TD></TR><TR><TD CLASS="quote">for that reason ok i guess, but if u want some cam gears that give u more power via acceleration, go edelbrock or fidanza</TD></TR></TABLE>
O RLY? How do those brands make more power?
Old May 9, 2008 | 03:54 PM
Toanz's Avatar
you're kidding right?
Old May 9, 2008 | 06:30 PM
lude98SH's Avatar
O RLY? How do those brands make more power?</TD></TR></TABLE>
lol
betta285
Jun 12, 2007 03:26 PM
sohctodohc
11
Jun 5, 2005 07:47 PM
coldfiremx
Mar 1, 2003 08:07 PM
sauceman
Jan 15, 2003 03:27 PM
b18c-93
Apr 4, 2002 05:10 PM
