Some Power Theory Questions
Old Jul 13, 2002 | 08:58 PM
ocbeta's Avatar
Default Some Power Theory Questions
I heard that HP is Tq x RPM Divided by 5252,
So a stock B18A1 which makes 121 tq (flywheel) at 6200 RPM has 142.8 HP,
If you were able to make peak tq at 7500
Say, for sake of example, no power gains were made through moving the peak torque, or adding the cams, you would be able to get 172 HP.
Now say, you have done a little work, and got an extra 10 lbs. tq, and got the peak tq to happen at 8000 rpms, you would have 199.54 HP!!!!!!!
Of course this is at the flywheel.
My question is this: How do you move the peak tq up the power band? Cams etc.?
Thanks,
Old Jul 13, 2002 | 09:41 PM
88crxoncrack's Avatar
Default Re: Some Power Theory Questions (ocbeta)
you're wierd
Old Jul 13, 2002 | 11:05 PM
JalopySiR's Avatar
I suck at math, but that sounds like a mathematical equation for camshafts to me.
Old Jul 13, 2002 | 11:50 PM
ocbeta's Avatar
Default Re: Some Power Theory Questions (JalopySiR)
I AM NOT WIERD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
See, I am not sure what kind of tunning this would require. Some people that I have talked to said it is a combination of a lot of things, compression, cam profiles, stroke, etc.
If this has to do with cam profiles, then that would be why most people don't get 40 HP from cams. IF you did a profile that extreme the car would not idle at all, or would have to idle at like 2000 rpm's.
Old Jul 14, 2002 | 01:28 AM
MikeSarr_GSR's Avatar
you can get 40whp from changing the system that creates
air speed velocity in your engine.
if you make peak efficiency in your engine at 6200 in a GSR
motor, then with some tuning to the manifolds by getting
a header, since we are talking about a B16, then an ITR mani
would help that as well as a 4-1 header. If you go with a setup
on your cams with more overlap at 0,0 then you will have
more overall power, to shift the tq higher, you could retard the
intake cam a degree or two maintaining 18BTDC on the ignition
timing... and retard the exhaust cam a degree or two. This
will make the engine see power later... not so much making more
later... you wont be faster.
cam tuning helps make more power where you want it,
fuel tuning insures that you make more power everwhere
once you find the best cam setting for overall power.
rememer... we still want MPG...
Old Jul 14, 2002 | 12:24 PM
ocbeta's Avatar
Default Re: Some Power Theory Questions (MikeSarr_GSR)
See, the B18A1 engine makes peak torque at like 5200 rpm, and peak hp at 6300 rpm. 6300rpm x 119 lbs. of torque / 5252 = 142 HP,
So, what would I have to do to make 120 lbs. of torque at say 7000? or 8000rpm?
Thanks
Old Jul 14, 2002 | 02:03 PM
Quick 200k Mile Motor's Avatar
I have a old B18A1, and was able to achieve 140 WHP & 128 WTQ with 92-93 camshafts.
Due to rod length, stroke (crank), bore, head port size & angle, and intake manifold, the B18A1 naturally breaths its best from 4000-5000rpm.
Excluding the modifications of camshaft, intake & exhaust manifolding,
the real way of shifting the peak torque (peak breathing) to 8000rpm, would be to change the geometry (rod, crank, & bore). I think this might require a taller block (more deck height) ..and notching of the insides.
Old Jul 14, 2002 | 02:32 PM
ocbeta's Avatar
Default Re: Some Power Theory Questions (Quick 200k Mile Motor)
Interesting. Thanks for the help guys.
dAndOg130
Nov 25, 2002 08:11 PM
osbornsm
Sep 24, 2002 04:23 AM
Pelican
Jun 18, 2002 05:39 PM
Veil_Side_
Oct 10, 2001 04:58 PM
